power steering pump leaks
Old Nov 26, 2005 | 10:36 PM
zsir's Avatar
zsir
My power steering pump leaks. it's not from the front seal or any of the hoses. Has anyone here ever taken the pump apart....is there a seal for the resivoir to the front of the pump...?
Old Nov 26, 2005 | 11:01 PM
wantaford's Avatar
wantaford
there is a big O-ring gasket between the pump and the reservoir.
Old Nov 29, 2005 | 05:59 PM
gdawghereiam's Avatar
gdawghereiam
p/s pump
what is the yr and make of vehicle?
Old Nov 30, 2005 | 10:20 PM
Ford_Six's Avatar
Ford_Six
If you have the newer style pump with the plastic tank, there is an o-ring in the joint between the pump and tank. IIRC, the older style is pretty much a single unit, but they can crack around the lower bolt if the weren't bolted down tight.
MOOSE_MACHINE
Jul 26, 2014 07:14 PM
willydad
Jul 16, 2014 05:57 PM
dazman
1978 - 1996 Big Bronco
Jun 8, 2004 11:30 PM
george walker
1997 - 2003 F150
Mar 6, 2004 04:12 PM
flatspin
Dec 21, 2001 06:34 PM
