help help
I have a problem with my f250 powerstroke.The truck quit running it was like some one shut it off.I have replaced the fuel pump ,glow plug relay coil ,fuel pressure reg.its was real cold outside the motor will still turn over i found a fuse blown its for the wastgate and injector driver module relay coil .Im not sure were the relay coil for that would does any body know it would a great help im lost in this truck on this thanks JOHNDEER
Sorry to hear about your problem. You will need to post your question in the tech forums since this one is used for introductions. Click on the Forums tab at the upper left and look over the various boards. You might want to try this one first: https://www.ford-trucks.com/forums/forum31/
Good luck and enjoy the site!
