help help
Old Jan 22, 2007 | 06:49 AM
johndeer68's Avatar
johndeer68
Cool help help
HELLO
I have a problem with my f250 powerstroke.The truck quit running it was like some one shut it off.I have replaced the fuel pump ,glow plug relay coil ,fuel pressure reg.its was real cold outside the motor will still turn over i found a fuse blown its for the wastgate and injector driver module relay coil .Im not sure were the relay coil for that would does any body know it would a great help im lost in this truck on this thanks JOHNDEER
Old Jan 22, 2007 | 06:57 AM
Ultramagdan's Avatar
Ultramagdan
Hello and Welcome to Ford Truck Enthusiasts!
Sorry to hear about your problem. You will need to post your question in the tech forums since this one is used for introductions. Click on the Forums tab at the upper left and look over the various boards. You might want to try this one first: https://www.ford-trucks.com/forums/forum31/
Good luck and enjoy the site!
Bludoe
New Member Introductions
Apr 28, 2007 09:36 PM
str8fancf
Mar 7, 2007 06:22 AM
Jack Brode
Feb 17, 2007 01:06 PM
CRGIFT
Jan 8, 2007 07:26 PM
johny b
Jan 1, 2007 07:19 PM
