I have a 86 Ford F150 V8, When the truck reaches 20 miles an hour it starts to sputter out and then the engine dies completely. I have replaced the high and low pressure fule pump, and fule injector, the distrubtor is new as well. I have been told there may be no fule pressure, but once the truck dies, i get underneith it to see if there is a clog in the line, there is plently of pressure so I know thats not the problem. I have been told to replace the Throttle Possition Sensor , any suggestions on that? I also have been told to replace the computer. I just need help!! Any suggestions will work!!
Sorry to hear about your problem. You will need to post your question in one of the tech forums since this one is only used for introductions. Click on the Forums tab at the upper left and browse over the boards. I think you will find several that will appeal to you.
You can also click on this link: 1980-1986 F100, F150 and it will take you to one of the forums that pertains to your truck.
