help what heads do i have casting numbers
Old Jan 22, 2007 | 05:23 PM
HemiEater's Avatar
HemiEater
thats normal..happens all the time...most likely umbrella type.
so, what we know....
they are not the good early heads because of the spark plug....
they have been machined for screw in studs
and you have rail type rockers.
did you see the questions Conanski had?
Old Jan 22, 2007 | 06:03 PM
robertbourque's Avatar
robertbourque
yes rail type. why wold some one put a stroker kit in this motor go 60 over and use cheap heads ?? also why would some one convert to stud mount and not do any other work to the heads and the exaust port has a thing in side the the port like a smog bump but not a bump a slope and they dont look ported on the exaust side would someone only port the intake side .also i compaired the spark plugs to my e7s and the heads are stubyer on the spark plug and the ones in this the plugs are longer .
Old Jan 22, 2007 | 07:12 PM
petes79f150's Avatar
petes79f150
REALLY need casting numbers from under the intake. They may not be "cheap" heads after all. If they're 68-76 302 heads, they could have 53.5, 58.2, or 63cc combustion chambers. The reason for converting to screw in studs is to keep the studs from pulling out because of higher spring pressures, usually associated with a more aggressive than stock camshaft. COST is usually the reason for NOT having port work done, if the person building the engine is not confident or knowledgeable enough to do it themselves. It is VERY labor intensive, especially with cast iron, and can be very expensive to have done correctly. Spark plugs will vary with combustion chamber size and design, piston design (dome or flat top) etc.
Pete
Old Jan 22, 2007 | 07:34 PM
robertbourque
im sorry i went and looked at them closer and there pressed in not threaded in .and this 302 block is very old like 70s still has the oil dip timing cover evrthing in sides like new even the heads .whats funny is the rods look like chevy rods but the exzust ports have dips in them .thanks for all the help
Old Jan 22, 2007 | 08:34 PM
baddad457's Avatar
baddad457
It may be a surprise to you, but most of the internal parts at first glance, DO look like similar parts of a Chevy. The valves and springs are interchangeable in some cases. Even Chevy connecting rods can be used in certain circumstances. A C9 head can either be a C9TE 302 head or the highly desireable C9OE 351W heads. Look under the valve covers for either. (302 or 351) Only thing that I question is the spark plug size. Should be 13/16" plugs, unless the engine's an oil burner (uses too much oil) and the previous owner installed anti-oil fouling inserts in the heads.
Old Jan 22, 2007 | 08:40 PM
robertbourque
all i can see is cp and a 15. no anti fouling inserts are seen
Old Jan 23, 2007 | 05:42 AM
HemiEater's Avatar
HemiEater
stock motor..............
RandallWhipple
Feb 7, 2015 04:58 AM
unclejunk
22
Sep 25, 2010 03:04 PM
460dragger
Aug 20, 2007 09:42 PM
fordf101968
Feb 14, 2007 08:23 PM
LastStarfighter
Apr 8, 2006 10:31 AM
