Steering box rebuild (kit)
Old Jan 20, 2007 | 03:47 PM
66 POJ's Avatar
66 POJ
Lightbulb Steering box rebuild (kit)
I need to rebuild my steering gear box, seems to be the demon of my play. Have any of you guys done it and were can I find a rebuild kit? It is a '66 manual box. I do this kinda work at work but on a larger scale so I feel I should be able to work my way thru it. Any suggestions..........
Old Jan 22, 2007 | 02:59 AM
NumberDummy's Avatar
NumberDummy
Ford Parts Specialist
There are three different gearboxes. One is for a 4X4, there are two for a 4X2,
See if you can find a number or tag on the box that reads: HCD-B; SMA-E or H.
If it's a 4X4, I don't need a gearbox number.
Old Jan 22, 2007 | 05:50 AM
jowilker's Avatar
jowilker
Frank, Might be a great time to convert to power steering.
John
Old Jan 22, 2007 | 05:05 PM
66 POJ's Avatar
66 POJ
Hello guys. Yeah I thought about upgrading and may do it, but will I be able to keep my stock column or have to cut it down? I'm sure I can find the swap info thru a search and I will do that as well.
But I may rebuild my stocker because I'm also ok with the strong arm steering.
My tag reads....
D B 1
6E12B
Hope you have the info ND.
Old Jan 22, 2007 | 09:45 PM
Lug Nut's Avatar
Lug Nut
I’m looking at doing the same either way. I just bough my truck as a work truck/project, and (among other things) the front end is whipped. I have near a quarter turn worth of play in the steering assembly. So I figured while I’m rebuilding it, adding power steering might be good idea, especially since I do a lot of driving in city traffic and paralyzed parking. Please let me know what you find, and I’ll try to do the same.
Old Jan 23, 2007 | 12:52 AM
NumberDummy
My tag reads....
D B 1
6E12B
There are two boxes. The two numbers I listed above are the only refs the parts book gives. However, only one part is different between the two..the steering worm and roller.
1-C5TZ-3524-B Shaft and rack (worm and roller) use with gearbox # HCD-B
......................................OR.......... ........................................
1-C5TZ-3524-G Shaft and rack use with gearbox # SMA-E or H
2-C2AZ-3552-A Race, Bearing upper & lower
2-C2AZ-3571-A Bearing Worm upper & lower
1-C5TZ-3575-D Shaft, Sector
2-C1AZ-3576-B Bearing, Sector Shaft (cased needle brgs)
1-C3AZ-3581-A Gasket, Sector shaft Cover
1-C7OZ-3591-A Seal, Sector Shaft
1-351701-S Plug, Sector Housing
1-B8AZ-3A657-A Shim Kit
mgerdau
13
Mar 23, 2017 12:03 PM
Nick-1973-ford
Aug 27, 2016 09:04 AM
ahawes
19
Jun 16, 2015 02:20 AM
jgcs1
Aug 15, 2007 02:24 PM
Ecartman
17
Jan 27, 2003 09:42 AM
