6.4L Power Stroke Diesel Engine fitted to 2008 - 2010 F250, F350 and F450 pickup trucks and F350 + Cab Chassis
6.4 training
Old Jan 20, 2007 | 11:10 AM
vloney's Avatar
vloney
6.4 training
I just got back from 6.4 training----------interesting! Lotta heat in the tailpipes, due to regeneration mode of the diesel oxidation catalyst- diesel particulate filter- and catalytic converter. It will set a rubber exhaust hose (like you find in the garages) on fire! Now, if you want to remove all of this--it is all tied in together with boost, egr,fuel timing. Ford realized there was some problems with the 6.0, so they were at times turning a blind eye toward some warranty claims, they do not anticipate any of those issues with the 6.4. THERE WILL BE ZERO TOLERANCE TOWARD MODIFICATIONS IN REGARD TO WARRANTY CLAIMS! Choose your mod choices wisely! Now, before you start shooting at me, I'm just relaying what the guy with FORD all over his shirt told me!
Old Jan 20, 2007 | 01:15 PM
vloney's Avatar
vloney
For you folks that think about bio-diesel, The catalysts dont like it. Use of more than 5% bio causes extra regeneration cycles in the doc,and the dpf, making extreme heat (1200 degrees). How do you feel about dash fires? Warranty wont pay for catalysts that were contaminated with un-approved fuels. How do you feel about $5000 out of your pocket? Again, when you change from the norm, it will make a big mess.
Old Jan 20, 2007 | 01:19 PM
vloney's Avatar
vloney
Ya Know the "searching" that the 6.0 turbo would do, and the stuck vanes? The 6.4, when you turn the key on, cycles the vanes via an electronic actuator, keeping everything freed up.
Old Jan 20, 2007 | 05:39 PM
carm_scaffidi's Avatar
carm_scaffidi
Hey, I appreciate all the information you are giving, thank you
Old Jan 20, 2007 | 05:57 PM
Powerstroke_wannabe's Avatar
Powerstroke_wannabe
It would be nice if they could make the 6.0 VGT cycle the vanes like that. Instead I romp on it a time or two each time I drive it to do my own "cycle".
By the way, thanks for sharing the info.
Old Jan 20, 2007 | 06:34 PM
rollerstud98's Avatar
rollerstud98
So is it the people who baby these 6.0's who have the problems then? Cause I'm always right into it and mines been solid for 2 years, except the alt went awhile back
Old Jan 20, 2007 | 09:21 PM
Jake4809's Avatar
Jake4809
vloney -- Thanks for the great info. I'll be happy to get my new truck and not touch a thing.
Old Jan 20, 2007 | 11:24 PM
kw5413's Avatar
kw5413
I think it's great. Just think of all the threads I will get to lock...or make disapear.... when people start complaining and looking for legal advice when Ford starts voiding warranties due to mods.
Old Jan 21, 2007 | 02:59 AM
SuperDutyJ4500's Avatar
SuperDutyJ4500
Awesome info..thanks for the post vloney.
Old Jan 21, 2007 | 05:19 PM
Offshor3's Avatar
Offshor3
The Saints lost, it's all over.
Old Jan 21, 2007 | 05:41 PM
vloney's Avatar
vloney
All the hype about the hp and torque was just that----"We just wanted to mess with dodges mind". It will be roughly the same as the 6.0---the curve will be a little different. The F250 we had there wasnt approved for on road use, so we couldnt drive it. Quite literally, you pull the cab almost anything you do to it!
Old Jan 21, 2007 | 06:05 PM
rollerstud98
how easy is it to remove the cab and re-install it?
Old Jan 21, 2007 | 06:10 PM
vloney's Avatar
vloney
They've improved several areas. The cab mounting bolts now come bottom up (before you had to remove carpet, and rear seats to get to the bolts) The shroud, and radiators (yes, radiators, 6 coolers up there) are easily removed. Everything else is pretty much unplug, and snap lock fittings.
Old Jan 21, 2007 | 07:55 PM
bnmccoy's Avatar
bnmccoy
Thanks vloney for posting the information.
Bob
Old Jan 22, 2007 | 03:30 AM
SuperDutyJ4500
So basically, removing the cab will be a smooth, clean process...that might save some time in the shop, and for the clients that need the truck back as quickly as possible.
