What Is This Called
Old Jan 17, 2007 | 06:54 PM
helpfulguy's Avatar
helpfulguy
What Is This Called
My Dad called and he has a question on his 88 f250. on the drivers side of the injector pump there is a part that bolts on and has two vacuum lines going to it.
  1. what is this part called
  2. what does it do?
I looked in my book and you can see pics of it in the haynes manual but no discription.
thanks for the help.
Old Jan 17, 2007 | 07:10 PM
lumbermansvo's Avatar
lumbermansvo
Sounds like a VRV(Vacuum Regulator Valve) to me. Does the truck have a C6?
Old Jan 17, 2007 | 07:38 PM
Ben-jamin's Avatar
Ben-jamin
if it opperates off of the throttle lever it is a vacuum regulator valve and controls the shift points for the trans (c-6); unless some one put a standard in and left the controll or else installed an injection pump off of an automatic truck
Old Jan 18, 2007 | 10:38 AM
helpfulguy's Avatar
helpfulguy
yes it is an auto and my dad thought it did something for the shifting just did not know what to call it when he went to the parts store. the guys at the part stores sometimes give old guys a trouble.
Thanks for all you help.
Old Jan 18, 2007 | 11:05 AM
CheaperJeeper's Avatar
CheaperJeeper
I'd be pretty surprised if he can get one at a parts store. More than likely a dealer-only item....
Old Jan 18, 2007 | 11:10 AM
lumbermansvo
Every part store I went to either said the part didn't exist or I was wrong about what it was. Showing it to them didn't help either.
The guy at the Ford dealer by my house know exactly what I was looking for without looking at the computer.
Old Jan 18, 2007 | 12:26 PM
Spectramac's Avatar
Spectramac
Did he break it? If he doesn't like how it's shifting, it's adjustable.
Old Jan 18, 2007 | 02:39 PM
helpfulguy's Avatar
helpfulguy
I don't know if he broke it but he said the barbs are broke off and he has it bypassed right now. he does not drive the truck much anymore but he likes to keep it kept up. I will call the ford house just to see what the one here says.
Old Jan 18, 2007 | 09:04 PM
Spectramac's Avatar
Spectramac
Sounds like it's broke then.
With the hoses hooked together it's probably shifting real early, huh?
jayro88
Jul 19, 2014 08:37 PM
RIKIL
May 25, 2012 04:36 PM
wizzard351
16
Jan 20, 2009 11:19 AM
etnies13
Feb 24, 2006 08:57 PM
Fishallot
1978 - 1996 Big Bronco
15
May 15, 2005 03:20 PM
