Stuck gas pedal
Old Jan 16, 2007 | 10:20 PM
myEXisFAT's Avatar
myEXisFAT
Stuck gas pedal
Sometimes when I get in to drive the gas pedal seems stuck ill have to tap it kind of fast to get it unstuck but once its free its ok, this can be dangerous any had this problem before? (97 exp)
Old Jan 16, 2007 | 10:42 PM
slenser's Avatar
slenser
I had this happen to one of my Mustangs a while back. The carpet was catching the gas pedal and causing it to stick. Some scary stuff to happen at full throttle!
Old Jan 17, 2007 | 01:31 PM
bingo begone's Avatar
bingo begone
me too
I am having the same probblem with the gas pedel in my '99 EB Expy. Once you get going, it loosens up, but you gotta mash it to get the stickyness out. Any ideas?
Old Jan 17, 2007 | 07:10 PM
ipbuys1's Avatar
ipbuys1
It's the same on my 2001 Expy 5.4L. I used to just push down on it but it would cause the truck to surge forward when it released. Now I tap it and then its fine. It only happens when the truck is cold and is perfect after releasing.
I've been meaning to spray some WD 40 on the cable but haven’t had a chance or maybe its some thing with the throttle body.
Old Jan 17, 2007 | 07:37 PM
FTE Herman's Avatar
FTE Herman
Historically, this problem is due to buildup in the throttle body. You might try cleaning it with TB cleaner.
Old Jan 17, 2007 | 08:15 PM
pitrow's Avatar
pitrow
yeah, what hkiefus said. Do a search on here you'll find it's a common problem. Easily solved with a little carb cleaner and a rag.
Old Jan 17, 2007 | 10:07 PM
tykateexcursion's Avatar
tykateexcursion
this happened to me. I got some 3M throtle body cleaner and a clean shop rag. when you spray the solution in try to coat the out side walls more than spraying down the throat of the throtle wipe as much of the build up out as you can. After you assemble everything let the vehicle sit a while so the vapors from the cleaner can disapate. If you start the truck right away the idel will be rough then sparatic idel then finally back to normal. The sticky pedal went away. The fix has lasted 2 years now.
Good luck.
John
2000 Eddie Bauer Expedition 5.4, AWD, 3.55ls Air suspension, Moon roof,Quad seats
2000 Excursion Limited, 6.8,2wd, 3.73ls
Old Jan 25, 2007 | 10:06 AM
jle70's Avatar
jle70
It is definitely in Throttle Body, if you disconnect Throttle and Cruise Control cables and work the Throttle cable with someone pressing on peddle and it moves freely. The butterfly sticks in the Throttle Body. Cleaning with carb cleaner will help, but it will still be a little tight due to the fact when Ford designed this, the cable is actually past center at idle so it does give a little resistance. But it shouldn't "stick".
Old Jan 25, 2007 | 10:25 AM
Phil056's Avatar
Phil056
Like all the posts above ^^^, cleaning the TB valve works wonders! Speaking of which I need to do it again, its been a while.
Old Jan 25, 2007 | 10:28 AM
jle70's Avatar
jle70
My next step is to remove TB and polish it with "dremel" so buildup has a harder time sticking to it.
Old Jan 25, 2007 | 11:43 AM
MisterCMK's Avatar
MisterCMK
DO NOT USE CARB CLEANER ON THE THROTTLE BODY!
The throttle body has a teflon coating and needs to be cleaned with throttle body cleaner and NOT regular old carb cleaner.
Old Jan 25, 2007 | 12:33 PM
jle70's Avatar
jle70
Does the standard carb cleaner eat the teflon?
Old Jan 26, 2007 | 11:07 PM
Hart 2000 EB AWD's Avatar
Hart 2000 EB AWD
My throttle was hanging as well...I decided to clean today...only took about 10 minutes. Take off the throttle body cover (3 bolts), loosen the screw the intake hose clamp and move the intake hose a little to the right...then used a rag sprayed with throttle body cleaner (Autozone, ~ $4) to clean around seat, valve, and throttle body throat. Mine was caked up and nasty...good as new now!
chadjones99
Oct 6, 2021 10:55 AM
Wigglesdabum
Dec 19, 2016 11:04 AM
BryceGreenleaf
Nov 27, 2015 06:44 AM
calbery
Nov 13, 2015 03:49 PM
93MARKIII
Apr 29, 2010 08:03 AM
