weird relay noise under dash
Old Nov 7, 2010 | 10:30 AM
chadjones99's Avatar
chadjones99
Hello , I have a 03 6L Ford F350 and for the most part trouble free
anyway lately I have been getting a clicking noise that sounds like a relay clicking under my dash when my truck is running even when its just idling
I don't always get it but it has become more common that last few weeks. So i stuck my head under the dash and it sounds like it coming from that little black box's that is attached at the base of the gas pedal ? could be coming from fuse box cause that what i was going to go after but doesn't sound like it, SO what is the little back box for on base of gas pedal
Old Nov 7, 2010 | 10:59 AM
chadjones99
Update ,not sure if its coming from that box, I took off fuse box cover and it seems like its coming from somewhere around the steering column area
Old Nov 7, 2010 | 08:37 PM
chadjones99
any help anyone ?
Old Nov 7, 2010 | 08:59 PM
bismic's Avatar
bismic
Any chattering relay is going to be hot also - maybe you could feel around and identify it.
Old Nov 7, 2010 | 09:20 PM
chadjones99
relay
i felt around look to feel the clicking i hear , but no luck. was reading another treat were someone said there glow plug controller was making a clicking noise. were is this located at so i can unplug mine after start up to see if it goes away
Old Nov 7, 2010 | 11:01 PM
redrock233's Avatar
redrock233
You might have a bad multi function switch. That is actually the turn signial sounds like the same thing that happened to me about 135 at dealler
Old Nov 8, 2010 | 06:31 PM
chadjones99
turn signal
well did you turn signal still work ? cause mine do
Old Nov 8, 2010 | 09:20 PM
redrock233's Avatar
redrock233
Yea it will all still work the same. The noise comes from just to the right of the stearing colum under the dash. I could not figure out what was wrong took it to the dealer and they charged me 350 for repairs part was only 135 i think
Old Nov 8, 2010 | 09:29 PM
chadjones99
i just swamped around the 12 volt relays in the fuse box and started truck and had to move a trailer in the yard.. did hear anything. but will know tomarrow
Old Nov 8, 2010 | 09:31 PM
chadjones99
plus I had the passager side seat fuse out and put it back in. didnt know maybe by having it was causing something else that feeds off of it other than seat ?
Old Dec 6, 2010 | 06:44 PM
chadjones99
Found the item that clicking need help iding it
Need help iding this item its bigger than a regualr relay , but its clicking alot even when truck is off but key is on.
sounds like a relay what is it. it is right behind the AC controls in the dash but lower not far off the floor board area
And heater and AC are off ( but do work )
Old Dec 6, 2010 | 06:48 PM
chadjones99
link to pics
trying to add pics off of face book but heres a link to them :
Login | Facebook
also will post in my user profile
Old Dec 6, 2010 | 06:49 PM
npccpartsman's Avatar
npccpartsman
Can't view your facebook page. You can attach a picture here using the manage attachments link.....or a different URL.
Old Dec 6, 2010 | 06:52 PM
chadjones99
posting to my user profile here ... right now
Old Dec 6, 2010 | 07:06 PM
chadjones99
ok there posted on my profile here . please look and see if you know what there are, sorry a little fuzzy , camrea real close
