My 48 was well preserved with an old layer of undercoating. But, try to remove it! Does anyone know of an application or a good way to remove the stuff without just scraping it off with a chisel?? thanks.
When I had it off I sandblasted the complete cab and in the cold weather the under coating came off very quickly.
Another way is some heat and alot of scraping but alot more work.
I would strongly suggest a good quality heat gun and putty knife over a torch. It's safer and cheaper. Also, I would never use gasoline for cleaning, gasoline fumes tend to collect toward the ground and expand out and can easily find an ignition source. Brake fluid might not be a bad choice, but be careful not to touch anything with a painted surface because it's a pretty good paint remover, down to the bare metal.
I of course assumed he would be doing this outside and not smoking next to it. Also a good point to mention not using the torch with the gasoline. Again I was making some assumptions there but good idea to post the disclaimers. Thanks fellows.
Also, I would do this in small sections and not an all at once application.
If it were me, I'd try popping off what I could with a hammer and chisel first. I may very well come off quickly in very large chunks, expecially if it's a bit chilly outside. What's left - try the heat and/or chemical approach and see what works best. I know the brake fluid works because the cement heads at my local Ford dealer made a mess when the replaced the MC on my 2003 F-250 and I now have a couple sections of exposed frame. Fortunately we don't see mcuh road salt down here so it shouldn't be a problem.
I had to strip some off the wheel tub area on my F-3's bedsides.. I used a propane torch to melt the stuff then hit it with a wire brush on my angle grinder. It made one heck of a mess, but worked great taking the undercoating and paint leaving bare metal (I do suggest doing this outside.. and a face shield is mandatory).
Any residue left over cleaned up easily with laquer thinner (yes I turned off the torch and let things cool first)
When I removed some of the same tar crap from inside the cab, I did it in late december/january when the temps were below freezing in my unheated garage. The stuff just shattered when I tapped on it with hammer and came off in huge chunks with a putty knife.
Get a block of dry ice. Press it against the undercoating for a couple minutes (wear HEAVY gloves and/or a pad of towels to protect your hands from frostbite) then hit it with a hammer (the undercoating, not your hand or the DI!) what doesn't shatter and fall off can be knocked off with a heavy putty knife. When it starts getting soft or stubborn, reapply the DI.
I used the heat gun, scraper method. The final cleanup was with laquer thinner. It was a bit of work but easier than just chipping it off with a chiesel. A respirator with the proper chemical vapour filters would be recomended if using thinners etc.
