Engine Swap
Old Jul 21, 1999 | 07:44 PM
Scott's Avatar
Scott
Engine Swap
Does anyone sell motor mounts to put a 302 into a 1960 Ford 150? The truck currently has a 223 with a 3 speed auto. I want to add a 302 and c4. Any suggestions?
Thanks,
Scott
Old Jul 23, 1999 | 03:41 PM
wvierra's Avatar
wvierra
Engine Swap
advanceadapters.com has the parts you need to do this
Old Aug 23, 1999 | 10:37 AM
Bob Hanser
Guest
Posts: n/a
Engine Swap
JC Whitney automotive has engine and tranny adapters also. Probably not as good of quality as above but probably less expensive.
Old Aug 23, 1999 | 02:17 PM
T.J.
Guest
Posts: n/a
Engine Swap
I have a 351w and c-4 I want to swap into a 1960 f-100, a 351w has the same bellhousing as a 302 right? Anyways you say that advance adapters has the mounts or JC whitney has them for such a swap?
Old Sep 1, 1999 | 10:56 AM
Bob Hanser
Guest
Posts: n/a
Engine Swap
Yeah, you can check out there web page at
www.jcwhitney.com and get a copy of their catalog. i think it runs about 75 bucks for a engine mount.
Bob
Old Sep 6, 1999 | 12:33 PM
docfestus's Avatar
docfestus
Engine Swap
Hi,
I would think you should not have much trouble finding the new mounts for the engine and/or tranny. Performance Automotive Warehouse has both in thier catalog. www.pawinc.com
Also Petersen's Custom Classic Trucks Oct 1999 issue has 1999 Catalog Request form for numerous catalogs. You should be able find what you need.
The 351w is just a tab wider and taller than a 302 but it should not be a problem. Good Luck, Doc
Old Sep 6, 1999 | 04:23 PM
mike's Avatar
mike
Engine Swap
quitcrab
Jan 29, 2017 06:30 AM
Scott Glenn
Nov 22, 2016 03:24 PM
scott73
New Member Introductions
Oct 21, 2007 05:35 PM
scott9050
Aerostar
Jul 8, 2002 06:08 PM
scott9320
Dec 4, 2001 12:31 PM
