1989 f150 xlt lariat 302 v8 engine compatibility
Old 11-22-2016, 09:25 AM
Scott Glenn
Scott Glenn is offline
Scott Glenn is starting off with a positive reputation.
Hello, I have to replace the engine in my truck. I have a 302 v8 efi in my 89 f150 xlt lariat. I have found a 302 v8 efi out of a 1990 f150. Is this engine compatible with the 1989? What is the compatible date range for the 302 efi? Would it be 1989 -1994? I'm trying to find the easiest swap possible without having to change computers, harnesses, etc.
Any help is appreciated.
-Scott Glenn
Old 11-22-2016, 03:19 PM
chrismd188's Avatar
chrismd188
chrismd188 is offline
chrismd188 is gaining momentum as a positive member of FTE.
There shouldn't have been any changes from 89-90
Old 11-22-2016, 03:24 PM
Freightrain's Avatar
Freightrain
Freightrain is offline
Shiftoholic
Freightrain has much to be proud ofFreightrain has much to be proud ofFreightrain has much to be proud ofFreightrain has much to be proud ofFreightrain has much to be proud ofFreightrain has much to be proud ofFreightrain has much to be proud ofFreightrain has much to be proud ofFreightrain has much to be proud of
Welcome to the forums Scott.
You can basically use ANY 302 motor, just have to use your intake and front accessories. That 1990 will likely be identical beyond something minor you need to swap over.
In my 1989 F150, I used a 1990 Mustang roller cam 302. Just put my intake and front accys on it. Trucks did not get roller cam motors til 95? Roller cam is not a deal breaker, but just an improvement.
78F-250Lariat
11-27-2017 06:16 PM
Glenn54
06-15-2017 11:09 AM
joseph.1234
06-07-2017 08:36 AM
texag1989
WTB - Parts & other
04-18-2017 05:25 PM
BuickBrian
04-13-2016 09:14 AM
Quick Reply: 1989 f150 xlt lariat 302 v8 engine compatibility
Contact Us - About Us - Archive - Advertising - Cookie Policy - Privacy Statement - Terms of Service
