turbo boost
Old Jan 15, 2007 | 06:35 PM
2 stroke man's Avatar
2 stroke man
turbo boost
i know that the boost on a 94-99 is less than the 99.5-03 7.3s. anyone know how much boost on there? what is concidered alot? the ones from 99.5 up are much more powerful with that bigger turbo. what about larger turbos?
Old Jan 16, 2007 | 03:08 PM
ryaneverk2's Avatar
ryaneverk2
Thread moved to 99-03 7.3L PSD section.
Old Jan 16, 2007 | 03:27 PM
CSIPSD's Avatar
CSIPSD
The turbos from the early 99s and the later 99s and up are not all that much "smaller" boost numbers will be about the same. OBS boost numbers are limited by the smaller injectors. You cant build boost without fuel. Too much boost is as bad as too little... Boost is heated air that you need to cool...
Old Jan 16, 2007 | 04:13 PM
2 stroke man
injectors
so how much diff is the injectors on the 2? could i put 99 injectors on the 97s?how much diff is there in them?
Old Jan 16, 2007 | 04:40 PM
PowerstrokeJunkie's Avatar
PowerstrokeJunkie
Yes, you can put stock 99.5+ injectors in an earlier truck. The earlier trucks have "code AA" injectors, which i believe are 95cc of fuel. The Early 99 trucks have AB injectors, which are about 115-120 cc of fuel. The Late 99 and newer trucks have Code AD, 135-140 cc of fuel if i am correct. You will need different tuning to accomodate the split shot injectors, and in the extreme tunes with the AD injectors, you may have a oil pressure problem due to a smaller pump.
A/Ox4
18
Jul 16, 2011 05:17 PM
The Dark Knight
6.4L Power Stroke Diesel
Jan 16, 2011 05:09 PM
kayjay7
Aug 12, 2007 02:41 AM
greenhedhntr
Nov 14, 2004 01:02 PM
Mustangfreak
Jun 27, 2004 12:52 PM
