Sponsored by: Real Truck
Annoying!
Old Jan 13, 2007 | 07:55 PM
THE KING's Avatar
THE KING
Annoying!
Hey, I got a 02 with the diesel. And i got a front end question. I live down a dirt road and if you hit a small pot hole or a washboard, NOT fast, But slow and it makes a huge rattling noise. I checked the ball joints and it seamed solid. I jumped on the chevy hooks and nothing. Im beginning to think its the sway bar end links. Please correct me if im wrong. And heres my other one. Going 55 mph, then you let off the gas and then apply it again it has a jolt and i can tell its coming from the rear end. What is it, U joint?? Hopefully not worse. Please help Thanks
Old Jan 13, 2007 | 08:00 PM
jake00's Avatar
jake00
shocks? mine were wore out and made all sortsa noises over small bumps
Old Jan 13, 2007 | 08:03 PM
conger's Avatar
conger
If it's u-joints it would probably make a clunk noise when your stopped and go from drive to reverse. Could also be sway bar bushings or the pos rancho shock if there still on the truck.
Old Jan 13, 2007 | 08:04 PM
wcurtis's Avatar
wcurtis
Check out the thread about the clunk noise
http://www.eurekaboy.com/f250/slipjoint.htm
Old Jan 13, 2007 | 08:06 PM
THE KING's Avatar
THE KING
My trucks not the FX4 Package. I think its got the original Bilstine shocks. Thankyou for your help!
Old Jan 13, 2007 | 08:17 PM
THE KING's Avatar
THE KING
In the link they state it clunks when puting the truck into drive. Mine is good when you shift. Its just when your at 55 and u get off the gas and lightly press it again. Im thinking Ring and pinion play. I hope not.
Old Jan 13, 2007 | 08:32 PM
conger's Avatar
conger
That's going to be a bit tricky to track down if it only happens a 55. Most of the suggestions your getting for us are typical of noise produced from a standing start. I just changed the oem Rancho's that my truck came with. One of the rear ones made a popping noise when compressed, but I never heard when moving. They were all completely gone. If yours came with the Bilsteins, your lucky. The Rancho's were a disappointment.
Old Jan 13, 2007 | 11:21 PM
redford's Avatar
redford
FTE Leadership Emeritus
OK, try removing your spare tire then drive your route.
Old Jan 14, 2007 | 12:45 PM
86mustang's Avatar
86mustang
I had the front end problem everytime I hit a bump it would rattle. It was the sway bay bushing on the axle.
Old Jan 14, 2007 | 04:41 PM
THE KING's Avatar
THE KING
Ok thankyou. Im gonna preplace everything anyways. Its due.
rpenterics
Sep 9, 2014 10:50 PM
RedLance
Feb 20, 2012 01:01 AM
whobock
Dec 27, 2011 05:52 PM
Rackpatrol
May 11, 2004 09:27 PM
alpine7572
1978 - 1996 Big Bronco
Sep 2, 2003 10:39 PM
