Axle parts
I did some searching and just got more confused, so I'm asking.
Picture if you will...Removed tire, calliper and rotor. Removed hub, and knuckle containing the stub shaft/spindle with it's yoke for the U joint. You are now looking at the end of the axle tube, with the axle shaft in it, one end connected to the differential carrier, the other end has the yoke for the U joint on it. Just inboard of the yoke, is a seal. Apparently it's called a "dust seal" is there a bearing behind this, or is the first bearing all the way in at the differential? When I was doing my brakes, I noticed the passenger side u-joint is shot, and the axle wiggles around in the dust seal. Figured I'd replace the seal while I was doing the U joint. Also, how do I get the axle shaft out? Just pull, or do I have to remove a C clip from the inboard end?
Can somebody give me the right National part number for the seal? I have a 6/2000 Excursion.
Thanks!
Brian
Thanks!
Brian
