block heater and other winter solutions
#31
Originally Posted by Barehuggs
Your Block heater will use 1000 watts whether it gets 110 volts or 130 volts at it's cord connection. (1000/110=9.09 Amps) (1000/130=7.69 Amps)
As Dave pointed out, you want the power to the heater, not the wire, so use the shortest and biggest wire that's practical. Also, make sure all connections are clean, tight, and protected from the weather as much as possible. If possible a GFCI breaker or outlet is a good idea just in case you do something silly early some cold, dark, and damp morning before all brain cells are firing...
#32
Sooooo, 11 months later I plug in my block heater for the first time since I bought my ride. I decided to see what kind of neat things folks have done with their heater set up and searched 'block heaters'.
It was nice reading not to coil the plug up, reading that sent me running out the house to the car-port and uncoiling the damn cord.
#35
#36
I agree with Dave in regards to cord sizing, however in the real world a saw only runs for a few seconds, a block heater is on constantly and just sizing up on the cord when you have an increased amperage draw is another can of worms to open.
Typically if you were drawing more than 15 amps you would need to have a larger breaker as well and also be sure that the wiring to the receptacle was sized accordingly as well. you can't just put a bigger breaker in.
I live in one of the coldest parts of north america and with my GPs working well my trucks NEVER need to be plugged in.
Always use the shortest cord possible, be sure the circuit can handle the load, and put a block heater timer on the whole setup, it will warm an engine up in 90 minutes.
#37
#39
x2^^^^. was gp condition and fuel system condition ever questioned back in 2007 when this thread started? if eveything is working right then you should not need the block heater at all. i use mine when the temps get below 50*F. helps with cab heat and gets oil pressure up faster. mine is on a timer as well.
#40
On one such bitter cold night, the insulation on my heavy duty electric cord SHATTERED when I was unrolling it. After that I bought a cord with a reputation for resistance of super cold, didn't coil it much if at all, and left it plugged in all night - to keep the cord warm!
The prewarmed coolant also helped the defroster defog the windshield right away, else my breath would generate ice on the inside of the windshield if I closed the windows, something I generally do at -25°F.
#41
Timer is a good idea if you are sure you won't need to start earlier than scheduled. On the other hand if you might need to start at any time of the day or night for safety or business reasons, you might dispense with the timer.
Also suggest some kind of indicator light where your power cord to the block heater is connected to verify that the circuit is live and has not malfunctioned. You should be able to look out your window & from a distance see that little light verifying the power is going into your block heater. Years back my circuit malfunctioned & cut the power in the middle of the night, resulting in a stone cold engine block just when I wanted to start up & go to work. It was one of those -25°F mornings I have referred to. I was a little late that day.
#42
after a day when it never got above -10°F and a night when it got down to -25°F,
I don't know where you live but -25 is mild here.
It can and will be -40 here in winter.
Last year we had 38 days when it never went over -25 day or night, always starts first try, your not driving a Chev are you?
#43
Nope, I was referring to the very first winter after I bought my 1983 Ford diesel NEW, everything on it was in tip-top condition at the time & having that thing start whenever I wanted was an obligation to me - I lost income if I showed up late.
#45
I hate winter yet I live in one of the coldest places a man could be in unless he goes to Northwestern Canada.
Pretty nice most times though, thing of it is, electricity is very expensive here so we have to manage our usage.
keep the trucks running good so they don't let you down, same as you, can't miss work.
redbug
25
02-19-2015 12:42 PM
dyoungen
11-18-2014 10:46 AM
nomula
09-24-2014 01:13 AM
86f250XLT-4x4
24
05-12-2013 05:10 PM
