Block heater change question
Old Nov 16, 2014 | 07:49 AM
dyoungen's Avatar
dyoungen
I'm changing the block heater on my 1987 F250 with a 6.9 Diesel N/A. The old one quit years ago and since I'm down for a couple things like IP and injector change thought I'd go back to using the block heater. Any suggestions when I change the element of what to do and what not to do? I got the block heater from NAPA and it looks like the one I need so now the fun begins. Any suggestions will be appreciated.
Old Nov 16, 2014 | 03:56 PM
bashby's Avatar
bashby
The cord goes bad more often than the heater. Id make sure you dont just need that.
Old Nov 18, 2014 | 08:05 AM
86pullerf350's Avatar
86pullerf350
Hmm I wonder if that would be my problem too on my 94 idi. How would I go about checking for a bad wire or element?
Thanks Bob
Old Nov 18, 2014 | 08:30 AM
bashby's Avatar
bashby
Check continuity with an ohm meter. At the plug that you plug into the ext cord, you should have continuity between the 2 flat terminals if tbe cord and heater are good. If not unplug the cord from tbe heater then check for cont between each of the flat terminals and the other end of the cord. You can also check the block heater itself but its hard to access.
Old Nov 18, 2014 | 10:46 AM
madpogue's Avatar
madpogue
You actually want to measure the RESISTANCE at the plug. The resistance between the two flat blades should be about 14 ohms. Then measure at the element (round terminals). Should be very close to the same. If it's "open" (infinite resistance) right at the element, the element is bad. If you get something close to 14-15 ohms at the element, the element is good. If so, and you get a lot higher resistance at the grille plug, or "open" (infinite) at the grille plug, the cord is bad.
David Fehir
Jan 22, 2016 05:25 PM
EXTREMEFUN1300
Dec 13, 2010 10:56 PM
WALJON
19
Dec 12, 2009 09:10 PM
bbull55
Feb 1, 2009 11:26 AM
immastrokinnow
Feb 23, 2008 10:43 PM
