Sponsored by: Real Truck
Beeper
Old Jul 5, 2007 | 06:21 PM
bryan21178's Avatar
bryan21178
so can i just cut the pink\black stripe wire at the inghion I am really not going to put that dame buzzer back on.
Old Jul 5, 2007 | 06:53 PM
thexman's Avatar
thexman
pulled the plug off like the post said, awesome! Quick, like 5 minutes. And it can be easily put back if someone insane bought the truck after me and wanted that noise again.
Old Aug 10, 2007 | 04:26 PM
dvferguson's Avatar
dvferguson
quik question
Even though I have a keypad entry does disconnecting the wire to defeat the dreaded dinging also affect whether the doors lock with the keys in the ignition?
Thanks
Dave
Old Aug 10, 2007 | 04:44 PM
Beerstalker's Avatar
Beerstalker
Dave, if you disconnect the wire as shown above you cannot lock the doors with the interior lock button while the doors are open, it will automatically unlock. The only way to lock the doors afterward is by pressing down the plastic plunger up by the window manually, or by shutting the door and then using either the keypad, or your keykess entry keyfob. I personally always lock my doors using either the keyfob or keypad so it isn't a big deal to me.
Old Aug 31, 2007 | 04:33 PM
cfd29's Avatar
cfd29
Well I guess I am blind, is it the darker blue wire with the fine gray line in it
looks like I can see several blue gray wires coming out of the that big block
for the 2008??
Old Aug 31, 2007 | 05:17 PM
Leader's Avatar
Leader
Rather then disassemble the stearing colume, just stick a punch in that fourth hole under the key cylinder with the key in the run position and pull the switch out. Then you can put a piece of tape on the top of the cylinder & reinstall it. Shouldn't take more then 1 Min. if you have the tape ready.
Old Aug 31, 2007 | 05:29 PM
cfd29's Avatar
cfd29
OK, but that wont work for a 2008, whole different animal..
Ignition switch completely different,
Old Sep 4, 2007 | 09:40 AM
Beerstalker
cfd, if you haven't figured this out yet it might be work sending Exposed a PM to see if he can't take a picture or something. Sorry I can't help any more than that.
Old Oct 1, 2007 | 10:28 PM
shockman's Avatar
shockman
okay i have an 08 gasser and have column apart, definately different than I've read on here I going back out to see if I can find right wire! wondering if chipped key might explain no visible contact in tumbler?? help!
Old Oct 2, 2007 | 11:00 AM
Beerstalker
Shockman, are you following Exposed's instructions I copied in post #14? That is the procedure for the 08 trucks.
Post #11 is for 99-07 trucks.
Old Oct 3, 2007 | 08:51 AM
shockman's Avatar
shockman
Okay I easily found a blue with grey tracer from column, but I'm scarred to cut it!! is it for sure the only blue/grey wire in that mess of wires, and will the only result be no more key chime???
Marc
Old Oct 3, 2007 | 02:40 PM
Beerstalker
That should be it. You can always splice it back together if it doesn't work.
Old Jan 25, 2008 | 10:10 PM
  #28
DaveWilliams's Avatar
DaveWilliams
Question
Do you happen to have a picture of where you would put the tape? Also would you use black electrical tape, masking tape or what? I am concerned about the glue or possibly the tape jamming something up. This solution sounds the easiest without taking the column apart. Someone mentioned that the drivers door will unlock if you lock them with the lock button. I would assume that this mod is fooling the system into thinking the key is NOT in place? I would think that if it thinks the key is NOT in place it would not kick up the plunger on the drivers side door. It does this to keep you from locking the door with the keys in the ingition.....anyone know for sure about the door lock thing? Thanks, Dave
Old Jan 25, 2008 | 10:41 PM
  #29
Musicman250's Avatar
Musicman250
Originally Posted by G'sRed99F150
The seat belt minder bugged the heck out me, took the advice to unplug the wire connector under the seat (real simple) and it works fine now, no more reminder. Now I did notice another plug in, it was yellow, first one was grey. (50/50 chance on getting it right) What is it for, I have no power seats or anything, just curious.
On my Honda minivan the yellow harnes and plug to the seats is the side impact airbags mounted in seat uprights. Be carefull!!
Old Jan 26, 2008 | 08:01 AM
  #30
D8chumley's Avatar
D8chumley
Resident smarta$$
This might be a dumb question mtpocket but for your back-up beeper, do you have a cancel button on your dash below the stereo? Reason I ask is b/c my truck has one, push the button in reverse and cancel beeper. Maybe its just something on KR's, just thought I'd add my .02. Mine beeps when I first put it in R to back out of the garage. HTH
