Roushcharger Installation: Before and After Dyno Charts
Old 01-11-2007, 03:01 PM
FTE Ken's Avatar
FTE Ken
FTE Ken is offline
https://www.ford-trucks.com/article/...no_Charts.html
The above article has the before and after Roushcharger dyno graphs several people asked about!
Old 01-11-2007, 03:50 PM
DRM2004's Avatar
DRM2004
DRM2004 is offline
Anyone spend the $5500 bucks on one of these? Do you like it? How about everyday reliability of the set up?
I do believe this is the way to go with a F-150 supercharger set up.....but I plan on keeping my truck for 200K+ miles. So I'll stay stock.
Old 01-11-2007, 04:25 PM
FTE Ken's Avatar
FTE Ken
FTE Ken is offline
I absolutely love it. There's no reason you won't get high miles out of a blower engine if you don't abuse it (same as with a non-blown engine). Lots of Lightning owners to back that up. Its why Roush keeps your 3/36 warranty intact on these trucks. Typically longevity isn't the reason someone passes on a blower, the $$$ is.
Old 01-11-2007, 05:41 PM
fordsinair's Avatar
fordsinair
fordsinair is offline
That would be NICE for towing and then playing when the trailer is off. I like.
Old 01-12-2007, 12:08 AM
Tylus's Avatar
Tylus
Tylus is offline
MMNC (SS)(Ret)
my wife is making me pick between the lift and the supercharger. the boost is winning the fight for me. just wish it wasn't so dang expensive.
so that 445 hp / 500 torque on the Roush website is flywheel rating? 329/372 are respectable, but I was expecting more in the 400+ range for almost $6,000
Old 01-12-2007, 08:10 AM
FTE Ken's Avatar
FTE Ken
FTE Ken is offline
Your F150 is currently making about 200-215 at the wheels. Yes, the drive-train loss is that significant. This will make it make faster than a Mustang GT because its generating 350 ft/lbs of torque right off idle. Its torque that counts.
Stay tuned for the next dyno graph article. There are some tricks that can be done that put it right where you're expecting to see it.
Old 01-13-2007, 02:55 AM
Tylus's Avatar
Tylus
Tylus is offline
MMNC (SS)(Ret)
can't wait. did your dyno runs also have the transmission tuned? or was it still on the anemic stock shift points?
Old 01-13-2007, 05:57 AM
WhëëlMå1's Avatar
WhëëlMå1
WhëëlMå1 is offline
I realize this is a silly question to ask..... but how bad was the hit to the mpg with this unit? I have to figure keeping the stoichiometric point correct, involves nothing short of a 2" diameter fuel line to the motor...
Old 01-13-2007, 09:34 AM
FTE Ken's Avatar
FTE Ken
FTE Ken is offline
Roush changes the stock shifting, though they still aren't optimal (at least not to my liking). More on this in the article on the custom tweaks we made.
As to the MPG, the Roushcharger has a boost by-pass so with normal driving there really isn't much of an impact to mileage. Besides... I live 5 miles from the office, 3 miles from the grocery store and 3 miles from a department store. Frankly I don't check mileage, its just not an important factor to me.
Old 01-13-2007, 04:58 PM
VFR_Man's Avatar
VFR_Man
VFR_Man is offline
I'm guessing your truck was built before Ford started building the Flex Fuel engines into the F-150's, but do you happen to know whether the supercharger will preclude using E85 in an FFV engine?
I would guess detonation is one of the bigger concerns, so E85 shouldn't make that worse, but I don't know what they do with the ECU programming, if anything, to run E85 that may foul up a supercharger installation.
Thanks for the great articles.
Old 01-13-2007, 05:15 PM
FTE Ken's Avatar
FTE Ken
FTE Ken is offline
That's a question for Roush. I suggest starting a new topic with an appropriate title. Roush has a rep here who might be able to answer this.
Personally, I wouldn't put anything other than the best (not the cheapest) fuel in my truck. A supercharger requires premium fuel, and its not just octane that matters, its total BTUs. 93 octane at one isn't as good as 93 octane at another. Around here, Shell is horrible. Citgo is borderline. Chevron is good. Murhpy (Walmart) is horrible. Quicktrip is, surprisingly, pretty good. BP = bad ping!
2007stlFX2
Vehicles for Sale
02-22-2013 12:50 PM
FORD996
2004 - 2008 F150
03-07-2010 02:13 PM
428fourby
2004 - 2008 F150
17
09-02-2009 08:28 AM
FTE Ken
Projects
12-08-2008 12:51 PM
FTE Ken
Lightning, Harley-Davidson F-150, Roush F-150 & Saleen F-150
02-18-2007 08:35 AM
Quick Reply: Roushcharger Installation: Before and After Dyno Charts
