2004 V-10 motorhome ? Wanting more power
The Mass Air Flow Sensor is inside the plastic air filter housing were the 4 or 5 wire connector goes that is the sensor by removing air tube you can gain enough access to spray sensor wire there is enough slack in the harness to leave hooked up
CRC makes an electrical spray that can clean the small wire in the sensor, called mass air flow sensor cleaner available at most auto parts stores
The sensor measures the mount of air entering the engine so the computer can calculate the amount of fuel to give and what happens is crud builds up on the sensor wire and causes a leaner than normal condition
By clearing the computer by disconecting the battery cable the fuel trim tables get reset in the computer and corrects mixture reading
As to the Banks chip all info I have researched it is only a generic tune that is not even worth adding, you could install the Brazel chip only and have a nice improvement with power and gas mileage
rawjuno46
Modular V10 (6.8l)
20
07-22-2007 04:51 PM
sunuvabug
15
08-22-2006 07:53 PM
10, 2000, 2004, 68, adequate, brazels, f53, ford, motorhome, motorhomes, power, programer, programmer, programmers, v10
