Modular V10 (6.8l)
2004 V-10 motorhome ? Wanting more power
Old 01-14-2007, 05:46 PM
rawjuno46's Avatar
rawjuno46
rawjuno46 is offline
Also is the Brazel chip better the the Bank one. Are you saying that with the Banks chip I will have to run Supper unl. There site says that it doesn't need higher octane
Old 01-15-2007, 09:14 AM
rawjuno46's Avatar
rawjuno46
Originally Posted by rawjuno46
What is the mass air flow sensor and where is it on the motorhome. What does it do for me to replace it?
back to the top
Old 01-15-2007, 10:54 AM
joe galas's Avatar
joe galas
joe galas is offline
The Mass Air Flow Sensor is inside the plastic air filter housing were the 4 or 5 wire connector goes that is the sensor by removing air tube you can gain enough access to spray sensor wire there is enough slack in the harness to leave hooked up
CRC makes an electrical spray that can clean the small wire in the sensor, called mass air flow sensor cleaner available at most auto parts stores
The sensor measures the mount of air entering the engine so the computer can calculate the amount of fuel to give and what happens is crud builds up on the sensor wire and causes a leaner than normal condition
By clearing the computer by disconecting the battery cable the fuel trim tables get reset in the computer and corrects mixture reading
As to the Banks chip all info I have researched it is only a generic tune that is not even worth adding, you could install the Brazel chip only and have a nice improvement with power and gas mileage
Old 01-15-2007, 06:02 PM
rawjuno46's Avatar
rawjuno46
Does the banks kit void your vehicle warrenty.
Also Joe did you notice a increase in fuel milage or does any one notice an increase in mileage with the kit?
Old 01-15-2007, 07:20 PM
lswartz's Avatar
lswartz
lswartz is offline
Nice looking motorhome. Have you put it on the scales to see how much she weighs? Then pull the the loaded trailer on them & weigh it too. Just a thought from a problem I had with my previous van.
Old 01-16-2007, 11:49 AM
rawjuno46's Avatar
rawjuno46
So it seems to me like there is no real need for the chip from Banks. I am probably just going to do the power pack system with the header and pipe and look maybe into doing the chip stuff later
Old 01-19-2007, 08:48 PM
rawjuno46's Avatar
rawjuno46
I get the power pack tomorrow without chip
Easytime
1999 to 2016 Super Duty
09-16-2014 01:05 AM
markhe
Modular V10 (6.8l)
12-03-2009 08:16 PM
rawjuno46
Modular V10 (6.8l)
20
07-22-2007 04:51 PM
1irondragon
Modular V10 (6.8l)
09-06-2006 10:30 PM
sunuvabug
15
08-22-2006 07:53 PM
Quick Reply: 2004 V-10 motorhome ? Wanting more power
