Sponsored by: Auxito
chassis lube
Old Jan 7, 2007 | 07:10 PM
deaddux's Avatar
deaddux
chassis lube
How can you find out where all the places are that need grease? The truck is a 2000 F150 4wd, I will be using a regular grease gun and also have a needle if needed. Any type lube recommended? Thanks
Old Jan 7, 2007 | 07:50 PM
Wilber15's Avatar
Wilber15
If the parts are still original, you might not have alot of places. Possibles are Balljoints, tie rods, pitman/idler arms, aftermarket u-joints.....
Old Jan 7, 2007 | 10:42 PM
steve(ill)'s Avatar
steve(ill)
you might as well crawl under and look. dont know what the last guy replaced. like wilber said, the original ball joints and drive shaf universal dont have zerks. i think there is one on the idler arm? dont remember the tie rods having one.
Old Jan 7, 2007 | 11:20 PM
Wilber15's Avatar
Wilber15
I'm pretty sure aftermarket's on all mentioned will have zerks. But originals aren't going to...
Old Jan 7, 2007 | 11:30 PM
galaxie641's Avatar
galaxie641
There are only 2 or 3 stock IIRC, idler arm should be one and maybe some tranny linkage if you have an automatic. I am no fan of sticking boots with needles to grease them does more harm than good IMO.
Old Jan 8, 2007 | 06:44 AM
Joe Finn's Avatar
Joe Finn
I agree with you Galaxie, about sticking needles in the boot. I did make an exception once though. My pitman arm started squeeking pretty bad so I gave it the "IV" and it stopped.
On a side note: about 3 months ago I replaced my original tie rod ends and ball joints. I was pleasantly surprised that there was still a good bit of "clean" grease in the boot (90k miles).
aphotic26
Sep 11, 2021 05:37 PM
Big-Red-Lariat
2009 - 2014 F150
Oct 30, 2014 02:59 PM
chi6488
6.4L Power Stroke Diesel
Aug 18, 2014 04:58 AM
mongo75
All Things Towing
22
Apr 5, 2011 11:51 PM
ALL BOY
Oct 24, 2007 05:50 PM
