help with electrical
Old Jan 7, 2007 | 03:34 PM
smokem331's Avatar
smokem331
Ok this is for you ford techs or any one that knows the answer. Im installing a ford oem remote starter I got the instructions from a friend at ford but he is now on vaca out of the country. So any way i Have a 03 6.0 f-250. I am looking for the iginition input/output wire according to the sheet i have it is red/green I have no wire like that at all on the ignition switch. Any ideas. Also the parking lamp output is suposed to be on the left kick panel and color is brown I dont have a connector there is it in the bulk of wires running through there? Thanks for any imput
Old Jan 7, 2007 | 05:48 PM
EnviroCon's Avatar
EnviroCon
Originally Posted by smokem331
I am looking for the iginition input/output wire according to the sheet i have it is red/green I have no wire like that at all. . . Any ideas.
Since there's no Red/Lt. Green wire, use a White/Yellow wire.
Grab the Brown Parking Lights wire from behind the headlight switch itself. The black plastic surround that the headlight switch sits in should have a small notch on the bottom that will allow you to stick a flathead in and just pop-it out (be gentle and don't force it out) without having to remove any part of the dash (the '05+ trucks are different).
Old Jan 7, 2007 | 09:23 PM
smokem331's Avatar
smokem331
sweet thanks for the info man.
Skip1970
Feb 7, 2015 03:08 PM
forddaddy
Electrical Systems/Wiring
Aug 21, 2004 04:10 PM
trublu98expy
May 4, 2004 08:36 PM
jim417
Feb 24, 2004 07:03 PM
1968F250LWB
Jun 10, 2002 11:57 AM
