Check Engine Light after Cat removal
Jan 6, 2007 | 12:49 PM
I just replaced my Cat on my '06 F250 6.0L with an MBRP Catalytic Test Pipe. As expected, the Check Engine Light came on upon startup. I disconnected and reconnected the batteries and the light went away until the next restart. What's the best solution?
Reason: Spelling
Jan 6, 2007 | 12:59 PM
I was not aware removing the cat would trip the CEL - can you pull the exact DTC with a code reader?
Mark
Jan 6, 2007 | 01:18 PM
Thanks for the reply. I do not have a code reader (yet). Is it worth taking to the dealer to find out?
Jan 6, 2007 | 05:12 PM
I take mine off and on all the time and never get a cel. The only plus I get with it off is it sounds goooood!
Jan 6, 2007 | 05:34 PM
i put an afe cat delete on my 2006 ps , i did not get any codes, just better sound and less restriction.
Jan 6, 2007 | 06:27 PM
Is there a sensor on the '06, behind the Cat, that could be the cause?
Jan 6, 2007 | 10:49 PM
No sensors. You can take it to Autozone and they'll pull the code for you for free. Dealer may make an issue of no cat.
Mark
Jan 6, 2007 | 11:31 PM
I wouldn't go no where near a dealer without the cat. 4X4's recommendation seems to be the best approach.
Tomfo23
General Automotive Discussion
Sep 18, 2014 01:49 AM
bpford800
Feb 12, 2009 11:33 PM
Rposton1
Jan 26, 2005 11:19 PM
fimar7
1983 - 2012 Ranger & B-Series
Jan 24, 2005 01:58 PM
bronconorwood
1978 - 1996 Big Bronco
Jul 6, 2004 04:55 PM
