1978 - 1996 Big Bronco
Removing the Cat
Old Jul 2, 2004 | 08:08 PM
bronconorwood's Avatar
bronconorwood
Removing the Cat
I have a Flowmaster 40 series on my 88 Bronco. I've had one cat taken off and want to have the second taken off. Will this make it significantly louder? Will my truck run OK without the cats? Do I need MIL eliminators to keep the "check engine" light off? Can I just cut it out and clamp in a pipe (I don't have a welder)?
Old Jul 2, 2004 | 10:32 PM
LEIGUY's Avatar
LEIGUY
is it a 302 or 351
i was gonna do that to mine...a 351...cut the 2nd cat and throw on aflowmaster...is it not loud enough?....is it loud in the cab of your bronco?...my friend has a 351 with out the 2nd cat and a stock muffler and it sounds good
Old Jul 2, 2004 | 10:34 PM
bronconorwood
It sounds great, but it is not loud enough.
Old Jul 2, 2004 | 10:35 PM
bronconorwood
oh, and its a 302. slight hum in the cab. not all that noticeable
Old Jul 2, 2004 | 11:02 PM
LEIGUY's Avatar
LEIGUY
mine sounds massive just without the muffler....its a 351 though.....if you cut more off you need to make your car run richer....and to do that you need a chip...to get any real improvement
Old Jul 2, 2004 | 11:06 PM
LEIGUY's Avatar
LEIGUY
but it will be louder...take it to a muffletr shoop and get longtube headers and a y pipe
Old Jul 3, 2004 | 10:05 AM
bronconorwood
I don't have the money for that. I just want to remove the cat. Do I need MIL eliminators? Will it run OK without it? All of the MIL eliminators that I can find online are for 4.9L Mustangs. I have a 302 Bronco. Since the sizes are so close will it work? Seems like size shouldn't matter. Rather the vehicle's computer system should matter. Please help.
Old Jul 3, 2004 | 12:15 PM
Blue'87GT's Avatar
Blue'87GT
Is the O2 sensor before or after the cat? If it's before the cats, then you shouldn't need any sort of MIL eliminators. On 5.0 Mustangs, you don't need them, as an "off road" pipe won't effect the sensors at all. However, if you're caught by the police during a routine stop, etc, things could get very rough. Try like $1000 per missing cat plus impound until it's replaced. Just get a different muffler, something like a Dynomax Race Bullet. It's a straight through design that'll be fairly calm at idle and pretty loud at full throttle.
Old Jul 3, 2004 | 11:26 PM
ecsmith0624's Avatar
ecsmith0624
I just finished putting a new engine in my '89 and I already had one cat missing so I just hollowed out the other one and am running a flowtech afterburner with 2.5" from the headers. I like the sound of it and it's just on the limit where as long as I'm easy on the throttle through the neighborhood the neighbors don't complain. My check engine light was on before so I'm not sure how to get it to extinguish. Good luck.
Old Jul 3, 2004 | 11:43 PM
spixican07's Avatar
spixican07
You could just put straight pipes out of the cat. They don't change the sound that much. Or you could put a glasspack on there, or pretty much any straight-flow muffler design. Headers change the intonation but not not the level of volume.
P.S. There's a reason those things are on there. Removing the cats off of your truck is not a "mod".
Old Jul 4, 2004 | 08:35 AM
bronconorwood
What if I just cut out the muffler? Meineke told me that it would actually be quieter than the Flowmaster and it would hurt my gas mileage. I have trouble believing either one of those things.
Old Jul 5, 2004 | 05:26 PM
LEIGUY's Avatar
LEIGUY
no, its louder....why are you talking to meineke about it?...they are way off. it havent noticed a difference in my mileage...
Old Jul 6, 2004 | 04:55 PM
Wakeboarder141's Avatar
Wakeboarder141
If you still have a Y-pipe, having the muffler cut off can actually be quieter than a Flowmaster.
Shwan_89HD
Dec 5, 2012 01:38 PM
Holiver31
Exhaust Systems
22
Jul 18, 2009 06:35 PM
broncobillyII86
Bronco II
Dec 4, 2006 03:31 PM
javgag
Nov 3, 2004 10:45 PM
scottya4
Aug 26, 2004 07:41 PM
