wiring a voltmeter
Old Jan 6, 2007 | 12:31 PM
sams78's Avatar
sams78
wiring a voltmeter
I have a 78 f-150 put some gauges in was wondering where is the best place to hook up the voltmeter not a pro when it comes to wiring some things Thanks
Old Jan 6, 2007 | 06:37 PM
ubereal2's Avatar
ubereal2
Red face Voltmeter
If' it's a voltmeter and not an ampmeter you can even hook that up to the battery and a good ground. If it's an amp meter you'll need to hook that up to the chargins system.
Bob
Old Jan 6, 2007 | 10:32 PM
Franklin2's Avatar
Franklin2
If you hook it directly to the battery, then it will read all the time and be a drain on the battery. Just buy a fuse tap at the store, wrap it around a fuse in the fuse box that is hot in run only, and hook it to that. It can be a radio fuse, a heater blower fuse, etc. Hook the illumination wire from the gauge to a blue/red wire under the dash. The blue/red feeds all the dash lighting.
Old Jan 15, 2007 | 04:56 PM
sams78's Avatar
sams78
Thanks for the information it worked great
ligito
Nov 13, 2016 07:35 PM
jusjoe
All Things Towing
19
Jun 21, 2015 05:41 PM
6978sghfbjklgdfsjhkl
Sep 1, 2013 07:08 AM
sixofspades
Aug 17, 2011 06:59 PM
merc62
Electrical Systems/Wiring
Apr 8, 2003 07:18 PM
