Sponsored by: Real Truck
steering locking up
Old Jan 3, 2007 | 09:28 PM
jssnodak's Avatar
jssnodak
Exclamation steering locking up
Just bought a used 2001 F350 7.3 PSD and am having problems with the steering. When I am setting still and try to steer it to manuver into a parking spot the steering not only turns heavy but totally locks up. Took it back to the place I bought it from and they tested it and said its nothing out of the ordinary for that type of truck. They said you cannot turn them when you are setting still. My concern is that there is no weight on this truck yet. It is an XLT with a 6.5' box. I intended to pull a fifth wheel camper with it and if you can't turn empty it could be a bearcat in tight places with some weight on it. They filled the tires to max pressure (75-80psi) and said thats all they can do. Like to have some input. thanks jssnodak
Old Jan 3, 2007 | 09:43 PM
redford's Avatar
redford
FTE Leadership Emeritus
Welcome to FTE!
You're kidding, right? They actually told you that Ford designed, built and sold a truck that couldn't have it's wheels turned when stopped?
No, that is not normal.
Your truck may be low on power steering fluid, may need a new power steering pump, may need a new steering gearbox or may need new power steering hoses.
Old Jan 4, 2007 | 12:13 AM
KGB's Avatar
KGB
I Have A 99 F250 Sd (not Psd) 4x4 It Also Had That Problem .
I Greased Front End And It Help With The Steering.
Tire Air Pressure Also Affects The Steering On My Truck Due To Weight Of Truck.
Old Feb 2, 2007 | 06:45 AM
medlin80's Avatar
medlin80
power steering
I can't believe no one has a solution for this problem. It appears to big enough that some one should have found a fix for it. I would sure like to know.
Old Feb 2, 2007 | 09:36 AM
99f350sd's Avatar
99f350sd
You should jack the front up and turn the wheel to see if it turns hard off the ground. Could be ball joints locked up or steering gear etc. Check front U joints at all angles for steering issues.
Dick
Old May 8, 2007 | 12:56 PM
mrblue01's Avatar
mrblue01
anyone find a fix for this? I am searching for it because I have the exact same problem. Cant turn AT ALL without rolling. Something has got to be worn out, but I cant start swapping out parts until I get it narrowed down a bit.
Thanks in advance!
Old May 8, 2007 | 01:07 PM
66f25red's Avatar
66f25red
It sounds like you are turning the wheels while stopped and your foot on the brake. It is not uncommon for the modern disc brakes and wide tires for the system pressure to bypass because the brakes lock the wheels, which must be able to rotate during this manuver. When you release the brakes does it operate satisfactorly?
Old May 8, 2007 | 02:10 PM
mrblue01's Avatar
mrblue01
I can let off the brakes, but if I have a trailer on and it wont "roll" without hitting the gas... the steering is locked. Only once the wheels turn can I start turning the steering. When backing up a trailer, I need every inch... if the wheels are pointed the wrong way, I have to roll a few more inches the wrong way before I can get it turned back the right way. Doesnt work out well.
I am doing a bunch of searches and I see lots of people have this problem (and some trucks work fine )... some people are putting up with it, some just say "try changing the fluid, pump, box, $, etc". No real fix yet?
Old May 10, 2007 | 02:50 PM
medlin80's Avatar
medlin80
From what I have found out it is the hydroboast. They can be rebuilt and ported to help with the problem. Talk to some one at AGR Performance they can give you the details. I have got other problems right now, I have got a steering box on order from them.www.agrsteering.com
99expyTN
6.4L Power Stroke Diesel
Oct 28, 2014 12:07 AM
93 mix 'n match
1997 - 2003 F150
Jan 9, 2011 07:11 AM
900rr
Jan 15, 2007 08:25 AM
gcozmo
Jan 7, 2006 07:31 AM
