IAC Valve
Old Dec 31, 2006 | 09:29 AM
goochkja's Avatar
goochkja
Smile IAC Valve
This may be a dumb question, but do I need to worry about any timing issues when replacing an IAC Valve?
Old Dec 31, 2006 | 11:11 AM
H0llywood's Avatar
H0llywood
i dont see why you think it may be a dumb question cause it maybe useful to all of us here as to the answer you get.
Old Dec 31, 2006 | 11:59 AM
amm888's Avatar
amm888
from what i've read about changing the IAC: no.
it's just a simple procedure.
i pulled the IAC valve on my brother's explorer: cleaned it, and popped it back on w/out any issues ('cept now the car actually holds an idle w/out stalling).
you should be good to go,
al
Old Dec 31, 2006 | 12:37 PM
kailor's Avatar
kailor
gooch,
idle air control valve replacement
1. disconnect negative cable (mine was 5/16" socket)
2. remove black plactic cover above carburator (10 mm)
3. unplug the 2-wire clip and lay wires aside
4. remove idle air control valve (shiny silver and cylindrical + some plactic)
this will all be just one part (8 mm)
5. remove old gasket
6. install new gasket (I did not use any type of gasket cement)
7. install new idle air control valve (O'Reilly Auto Parts, Borg-Warner $73.43)
make sure to get and install a new gasket
8. re-connect wire plug
9. re-install shroud
10. reconnect negative battery cable
11. start engine, DO NOT TOUCH ACCELERATOR, let run for 15 minutes so
the computer can learn and integrate parameters of this new part
12. with the proper tools, 30 minutes later and you are done!
13. you just saved $100 - $150
Old Dec 31, 2006 | 07:40 PM
goochkja's Avatar
goochkja
thanks, i will give it a shot!!
Old Dec 31, 2006 | 07:41 PM
goochkja's Avatar
goochkja
thanks for the input!!
hambass
Mar 8, 2017 11:12 PM
nagetech
Jun 1, 2011 09:45 PM
f150nca
2004 - 2008 F150
Apr 21, 2011 09:57 PM
bigrigmike
Dec 20, 2010 04:53 PM
cactusbronco
1978 - 1996 Big Bronco
Aug 3, 2005 08:01 PM
