Clean IAC and Throttle Body
I looked under the hood..and it LOOKS simple, but I figured I'd gain some confidence from the good members of this forum thorugh whatever tips/guides/pics that may be provided! Truck just hit 100,000 miles *tear* so I'm sure a little love in the above mentioned departments will prevent any headaches down the road
I've never cleaned the IAC before so I can't be of any help to you. I have cleaned the throttle body. Make sure you use carb cleaner that is suitable for O2 sensors and catalytic converters.
I was scared of cleaning my MAF as well at first, but I just followed the instructions in the V10 forum and it was quite easy. Just spray the wire with the MAF cleaner, but don't touch it at all. Let it dry and make sure that there is no moisture condensation because the cleaner has a solvent that evaporates quickly...making the parts cold. Kinda like how your beer bottle gets wet on the outside on a hot humid day.
Disconnect the negative terminal on your battery prior to your doing this so:
1. You don't short anything out.
2. You clear the computer memory so it relearns the newly cleaned sensor and adjusts accordingly.
It'll help if you get the security star screw bits to remove the sensor from the housing.
I just did my old mans throttle body (2006 e250 van) and I had to take it out to really get in there to clean it out (tooth brush and all) and to clean the valve it hooks up too (was dirty as hell in there as well) I figure if I'm going to do this, taking out the throttle body would be the best way to go!
Also, from what I have read, the IAC valve is hooked up right near the throttle body...so it should definitely be easy to do while I'm in there.
A few pics here:
https://www.ford-trucks.com/forums/1...eanup-day.html
Haven't tackled the IAC, but need to.
Not yet!
I am learning to do this stuff as I go. I am NOT a mechanic by any means, but am competent enough to learn and do it, espeically so if I have a guide to follow! I have basic tools for dianosing and troubleshooting, and have enough common sense that I can figure out most problems (with the help of google and this forum of course).
I have read guide after guide about spark plug replacement, and can say that is a bit over my "experience" right now. Espeically when I read about how the back 2 are a bitch to get to and risk them breaking and such. Once I tackle these projects, I'll go from there to my next little venture
We all have to learn somewhere, and the X I feel is an excellent learning tool and well worth the effort
Yep, taking it off makes it MUCH easier AND the best stuff I've found is Seafoam. It just melts the black carbon build-up off. Pour some in a small cup and then go after the TB with a toothbrush. Then run some of the Seafoam thru a vacuum line and smoke out the neighbors.
