390 Carb Help
Old Dec 31, 2006 | 07:50 AM
ozzie65's Avatar
ozzie65
390 Carb Help
Any suggestions for replacing a balky 2 barrel on my 65 4x4 390 ? I'm considering a new carb and manifold. A HP boost would great, but mainly looking for quality/reliability. Is there a recommended package ?
thanks
Old Dec 31, 2006 | 08:36 AM
1949f1's Avatar
1949f1
i put a edelbrock performer with a 600 edelbrock carb on my 390.it run's a 100%.better. plus you loose that heavy old intake.
Old Dec 31, 2006 | 08:59 AM
66 POJ's Avatar
66 POJ
I am in the process of doing this also. I am using the 650 Thunder series from Edel.
Old Dec 31, 2006 | 12:48 PM
customcab66's Avatar
customcab66
I put a 4bbl intake off of a 1964 ford t-bird and a 650 holley carb.
Old Jan 1, 2007 | 08:32 AM
chadwickma's Avatar
chadwickma
I'm looking at the Edelbrock Performer 390 (part number #2105) intake with a Performer Series 750 cfm carb (part number #1407) for my 352. Both can be had on eBay for around $500 total.
Old Jan 1, 2007 | 08:47 AM
jowilker's Avatar
jowilker
Chad, The 750 is a little more carb than the FE can use, 600 CFM or less can actually run better without dumping as much gas out of the tailpipe.
John
Old Jan 1, 2007 | 09:00 AM
chadwickma's Avatar
chadwickma
Thanks for the info jowilker! Make that a Performer Series 600 cfm carb (part number #1405)
Old Jan 3, 2007 | 10:35 PM
ozzie65's Avatar
ozzie65
Thanks for the input guys - you saved me a lot of time and money
Old Jan 4, 2007 | 05:47 AM
jowilker's Avatar
jowilker
Ozzie, Unlike 1949f1 I really didn't notice much difference changing the intake and carb. Replacing a real ratty carb could show some improvement.
When I rebuilt my engine, I put the Edelbrock Performer intake and 1406 600cfm carb on it, but still thought it used too much gas. I have run a 390 cfm Holley 4 barrel that seemed to perform about as good as the Edel. and the mpgs went up. I have run a Holley 600 GT on it for a bit and did see a huge difference, but I couldn't stay out of it because I loved the sound and feel too good, and took it off.
There are a lot of guys running large carbs that will tell you they do a wonderful job, and if you bend over and sniff near the tail pipe you can smell the raw gas that is being dumped out on the road because the engine can't burn it. The pipe is generally sooty black too. IMHO
John
Chaosracing
Feb 11, 2015 04:43 PM
73BlackBeauty
Nov 13, 2008 07:13 AM
dwestcessna
Aug 26, 2008 07:20 PM
brucelee
Sep 19, 2005 06:46 AM
flyoutwalkback182
17
Feb 19, 2003 10:30 PM
