Sponsored by: Real Truck
Child Restraints?
Old Dec 30, 2006 | 05:08 PM
cowpokes74's Avatar
cowpokes74
Child Restraints?
I have recently purchased an '07 Crew Cab. When I got home, I realized it did not have the lower anchoring system, located in the back, for child seats. I previously owned a 1500 HD, which had the anchors. Is this normal that my truck does not have the child restraint anchor system?
Old Dec 30, 2006 | 09:50 PM
ReAX's Avatar
ReAX
Ford saved $1 leaving them off and you will have to pay $50 to get them is a normal policy for all manufactures. My 02 only had upper points.
Old Dec 30, 2006 | 11:29 PM
NoMo's Avatar
NoMo
Welcome to the site 'pokes.
Only the upper anchors are provided (along bottom of back window). You have to use the seatbelts for securing the child seats. Not as easy as the LATCH connectors, but still very functional.
Old Dec 31, 2006 | 12:34 AM
cowpokes74's Avatar
cowpokes74
Is there an "after market" option to adding the anchors? I am using the seatbelts for time being, but thought it wouldn't be an issue after getting rid of the oldest vehicle, the 2000 explorer.
Thanks!
Old Dec 31, 2006 | 12:43 PM
ReAX's Avatar
ReAX
You could get some uppers and have them drilled out. Then unbolt either the front seat bolts or the seat belt bolts behing the seat. If you use the seat belt bolts, put the seat belt loop on top of the anchor so it has some play to move.
Or, just get any ancho you like, some fender washers, bolts and lock nuts. Just go right through the floor with fender washers to disperse the load.
rougeriver
May 19, 2018 09:07 PM
rodderz
Jan 27, 2015 06:21 AM
HwyXingFrog
2004 - 2008 F150
Jul 26, 2012 03:27 AM
canadajin
Oct 15, 2004 07:12 PM
JRMoates
Feb 24, 2004 02:59 PM
