child restraint bolt
Old Jan 25, 2015 | 06:47 AM
rodderz's Avatar
rodderz
Hi all
I have picked myself up a 1985 f350 dual cab im wondering if the rear seat has child restraint bolts anywhere the rear seat is one that folds down to a bed im wondering if there is a bolt on the floor or on the back wall that could be able to be used.
Thanks
Rod
Old Jan 25, 2015 | 07:23 AM
Franklin2's Avatar
Franklin2
The only thing that year truck would have as far as restraints are seat belts. Check the area for rust, rusty areas around seat belt fastening points make them useless. The seat belts are usually fastened in re-enforced areas in the floorboard.
Old Jan 25, 2015 | 07:41 AM
TheCoach's Avatar
TheCoach
Originally Posted by rodderz
Hi all
Thanks
Rod
I asked this question not too long ago. There is no bolts and obviously no latch. But if the seat belts and are good shape you won't have a problem. My son rides in his car seat back there everyday and it ain't going anywhere.
Old Jan 25, 2015 | 10:37 AM
Nothing Special's Avatar
Nothing Special
Hi all
Thanks
Rod
What cab are you talking about? Ford never called anything a dual cab. I think Toyota calls their crew cab a dual cab, but I didn't think '85 Ford crew cabs (four doors) had back seats that folded flat. So I'm thinking you're asking about a Super Cab (2 doors).
Old Jan 25, 2015 | 04:25 PM
rodderz's Avatar
rodderz
I know them as a dual cab but yes you are correct i think for call them a crew cab. Its a 4 door with a rear bench seat that lays flat like a futon bed. Hope that helps. Here in aus child restraints need a seat belt and an anchor point i might have to get one engineered to meet safety requirements.
Thanks
Rod
Old Jan 27, 2015 | 06:21 AM
Archion's Avatar
Archion
Veteran: Marine Corps
Child restraints attachment points weren't a thing until the late '90s/early '00s. This generation won't have anything. You could probably fab something, but would require a welder and some time. Points other than the OEM seat bolt locations are not strong enough to resist tearing in an accident.
https://en.wikipedia.org/wiki/Isofix
ProjectPaxton
Apr 27, 2018 11:32 PM
pumpdriver20
Apr 2, 2011 06:28 AM
Pele
Jun 11, 2010 08:59 AM
Blue50F-1
Jul 20, 2005 05:13 PM
Menroid
Jun 2, 2003 04:24 PM
