Carburetor ??
Old Dec 30, 2006 | 11:32 AM
E30tdf's Avatar
E30tdf
Carburetor ??
I have recently pulled my 86 4X4 460 to clean up the oil leaks and put a straight up timing chain set in. I also removed some of the polution stuff to see how it would run without it.
It idles beautifully now. However, when I first hit the throttle it will sputter and maybe cough and then accelerate fine. I'm thinking that the 600 cfm holley may not be giving the engine enough fuel from the accelerator pump and it leans out with a sudden throttle opening.
Do I need larger or smaller shooters in the holley? It has a 1 year old holley 600 cfm model 4150 double pumper and it's a manual trans.
What else could cause the symtom?
Old Dec 30, 2006 | 01:11 PM
E30tdf's Avatar
E30tdf
After driving it again, I'm now thinking vacuum leak. Bonus air getting in with the fuel air mixture.
Old Dec 30, 2006 | 02:13 PM
E30tdf's Avatar
E30tdf
Yep! Had a small uncapped vacuum port at the very bottom of the carburetor!
Old Jan 4, 2007 | 08:09 PM
bigred460's Avatar
bigred460
in your opinion how much improvement was there with changing the timing set without any other mods? im looking at digging into mine this weekend to see if that has been done already when my father had it rebuilt in 98 or if they just put on a stock replacement. he removed all the emissions crap too back then. now i can only use it less than 5000 miles a year with the new laws. however if i drive 1000 a year im doing good thus far it seems.
Old Jan 6, 2007 | 09:23 PM
E30tdf's Avatar
E30tdf
You will notice an increase in torque right away with the straight up timing set. I can't quantify how much, but if you put it on a dyno it is measurable I'm sure . I also had my distributer recurved. I forgot to mention that in the original post.
Has anyone else had similar issues as mine (leaning out on throttle response) after pulling the thermactor system (air pumps)? I'm still running an EGR.
Old Jan 24, 2007 | 03:40 AM
E30tdf's Avatar
E30tdf
Well gentlemen, I got out the vacuum guage again and started checking vacuum again and I learned something (new for me at least).
The vacuum reading is not the same at every available port on the holley 4150. On my engine I had attached the vacuum line for the distributer to the lower port which was pulling 5 lb. more vacuum than the port near the top of the carb. The lower vacuum was 15 lb. The higher reading was 20 lb.
Consequently, I had too much vacuum advance on my distributer as set up. Moved the line to the upper port and things got a lot better.
I still may need some larger squirters to get the stumble fixed completely.
Old Jan 25, 2007 | 12:22 AM
DeanG's Avatar
DeanG
Besides the larger squirters you might want to go to a more aggressive accel pump cam. Find yourself a book on Holleys and do some research. You might even want to consider a 50cc accelerator pump kit. I used to run a 600 on a built 400 and had it tuned to the point where the off-idle pickup was as good as fuel injection. I run a built 460 now with a 770 Truck Avenger but the tuning principles are still the same. A 600 on a stock 460 should be adequate.
Old Jan 25, 2007 | 02:18 AM
Bear 45/70's Avatar
Bear 45/70
I have never seen a street engine that needed a 50cc pump. It is strictly a race item.
Old Jan 25, 2007 | 07:05 AM
E30tdf's Avatar
E30tdf
I had already purchased the acceleator cam packet, but have so far only tried one new combination.
So Bear, what do you think is going on? From your signature, it would appear that you are up on all these problems.
Old Jan 25, 2007 | 11:00 AM
Bear 45/70's Avatar
Bear 45/70
Generally vacuum leak (which you found already) or the accelerator pump linkage is not adjusted properly causes almost all this type of problem unless it is a timing issue. Having manifold vacuum to the dist. vacuum unit at idle can cause this.
Old Jan 25, 2007 | 11:07 AM
E30tdf's Avatar
E30tdf
Thanks Bear! I like this forum and the people here show a lot of knowledge and class. Us WA fellas will have to get together sometime.
Old Jan 25, 2007 | 11:25 AM
Bear 45/70's Avatar
Bear 45/70
Where in Washington are you located?
krazyness
23
Sep 29, 2016 07:56 AM
forestgreen
Oct 29, 2015 04:14 PM
Jnissen04
Apr 15, 2014 11:14 AM
CB-R
Aug 13, 2012 09:38 PM
allwthrrider
Aftermarket Products
Jan 30, 2012 09:05 PM
