cold idle ?
Old Dec 29, 2006 | 10:08 PM
muddingmcdude's Avatar
muddingmcdude
cold idle ?
is there any way to put the cold idle ona toggle switch so it stays on longer.??? and is there anyway to put teh glowplug thing on a toggle that way it doesnt have to come on all the time cuz i use my truck to deliver soo its shuts off alot thru the day and on and i dont even neeed the glow plugs it seemes i can just start up and it starts just as fast then if i let it cycle? i dont know.. just curious? thru the day that is i need them for the morning start or a cold start but even its if sits 1 hour it still starts right up.. ??? im worryin about it burning them out and the relay
Old Dec 29, 2006 | 11:04 PM
bc6.9's Avatar
bc6.9
I had my 86 for 10 years and only replaced the glow plugs once...cold starts were never a problem, never burned out the relay or the plugs....if your plugs come on and cycle, that means there are working the way the're meant to, so put your mind to rest.
Old Dec 30, 2006 | 12:15 AM
PLC7.3's Avatar
PLC7.3
Cold idle info.....from an old post
Very easy...
Find a switched power from under your dash panel, run it to a switch, then the other side of the switch to the High Idle Solenoid on the Injection Pump... But cut the wire leading up to the high idle solenoid, and install a diode with band side facing towards the solenoid, then land your homemade idle circuit wire there (between the diode and solenoid). This will keep you from feeding power back into the circuit and also keep you from engaging the timing advance when you manual control is engaged. But the system will still function just like stock, ie. no change will be seen or felt.
go to local radio shack and get a (this is from memory) 4001 diode... I can't seem to remember the part number on the diode but it has a 4001 if I remember correctly...
Old Dec 30, 2006 | 11:40 PM
muddingmcdude
plc7.3 does ur truck go right into lock up if u floored when it goes in to 2nd gear right in to lockup? cuz mine does... it just seems like my tranny is totally differnt now sence i got teh new motor expecially when it goes in to over drive ...
atomicglock
Oct 22, 2013 11:08 AM
indyF-350psd
41
Sep 20, 2012 12:34 AM
Raider50
Jul 15, 2009 06:35 PM
ky-rhino
20
May 16, 2009 10:54 PM
okiebronco
Computer Chips & Tuners
Feb 19, 2003 06:43 PM
