4x4 engine perches
Old Dec 29, 2006 | 09:04 PM
Rodder41's Avatar
Rodder41
Talking 4x4 engine perches
Does anyone know where i could find the engine perches for a 300 six to fit a 1971 4x4? I believe the two wheel drive mounts are different. I currently have v8 perches in mine.
Old Dec 30, 2006 | 07:24 PM
tex2046's Avatar
tex2046
Is it an F-100 or F-250? If it's an F-250 I have a set in my truck. What motor perches do you have? Small block,or FE block? I might be interested in trading.
Old Dec 30, 2006 | 09:01 PM
havi's Avatar
havi
I'll have the Roast Duck
Look on your frame for bolt holes next to the holes your mounts are currently bolted thru, that's where your mounts will need to go for the 300. If it had an FE, just move them to those holes, and done. If not an FE, you'll need 4x4 mounts from a 300 or FE. 67-72 forum might give you better info.
Old Dec 31, 2006 | 08:53 AM
Rodder41's Avatar
Rodder41
Havi, i know where they go i just need a set to fit the 300 as the fe ones are different.
Old Dec 31, 2006 | 09:25 AM
havi's Avatar
havi
hmm, must be just the 2wd ones that are the same?
Old Mar 19, 2007 | 08:48 PM
highboyblue's Avatar
highboyblue
havi,
My 70' f-250 4x4 had a 390. We moved the perches forward 3" (used 4/6 existing holes) and the 300 motor lmounts bolted right on!
highboyblue
Old Mar 19, 2007 | 09:21 PM
havi's Avatar
havi
it's always been my impression that the frames on the assembly line are all the same(4x4's). It's everything else bolted on afterward that dictates what's what. Cost savings. I'm not familiar with 67-72 frames, other than front clips and cabs bolt onto 73-79's. However I am familiar with 73-79 frames, and 4x4 f150's/78-79 broncos are the same, 73-early 77 4x4 f250's same, etc...so, it was an educated guess....glad it proved true, as I've learned something today.
PS:that's why I made an attempt(and succeeded) to put a 300 in my 79 bronco.
Green Streak
Engine Swaps
Sep 23, 2019 05:18 PM
bsiebert
Jun 18, 2016 12:27 PM
crusty77
Oct 5, 2013 07:20 PM
squirrel1182
Jul 3, 2012 11:26 AM
Boss50
Engine Swaps
Jun 17, 2006 06:26 PM
