Insulated Concrete Forms
Old Jan 5, 2007 | 02:49 PM
  #31
DOHCmarauder's Avatar
DOHCmarauder
Originally Posted by chrono4
for outlets they just cut out the foam behind it and fasten the boxes to the cement/drywall
So you basically carve out foam wherever you want romex or pipe etc...???
Old Jan 6, 2007 | 01:30 AM
  #32
chrono4's Avatar
chrono4
Ya, they use heated electrodes, and just cut out for wire and whatnot.
Old Jan 6, 2007 | 06:57 PM
  #33
1975Ford's Avatar
1975Ford
Toyman, thanks for the pictures and info, nice wall system.
Chrono4, What is used to fasten the electrical boxes?
Old Jan 6, 2007 | 08:09 PM
  #34
1975Ford's Avatar
1975Ford
Another list of ICF and Accessories for Construction
http://www.cement.org/homes/ch_bs_icf.asp
Old Jan 8, 2007 | 09:34 PM
  #35
1975Ford's Avatar
1975Ford
Insulated Concrete Homes Build
Has anyone ever used Insulated Concrete Forms (ICF) to build a home, or an addition with this product?
What was the product brand?
What was the building process for using this product?
Old Jan 10, 2007 | 08:23 AM
  #36
fred_79f250's Avatar
fred_79f250
Another option : I've been researching pre-cast foundation wall systems.
That is, they pre-cast basement wall sections at the factory, then install them onto your footers. An entire house foundation can be installed in a day. And because the concrete is poured in controlled conditions, they can use very tough, non-pourous 5,000psi mixes. Many manufacturers add wood studs and insulation right into/onto the concrete, so your inner wall is already ready to go too.
Not sure about the cost - but it looks like a great idea especially for cold climate construction.
Old Jan 10, 2007 | 11:55 AM
  #37
1975Ford's Avatar
1975Ford
What is the systems brand name?
Toyman is using Superior Wall, and sound familar to the system you have described.
Old Mar 15, 2007 | 10:32 AM
  #38
1975Ford's Avatar
1975Ford
update, I decided to use ICF 24 inch wide forms for the footers around the home wall.
Will use either EcoBlock, or Reward Wall for stem wall and the exterior walls.
Should be breaking ground on my new home in April , getting real excited.
CretePumper
15
Jul 15, 2009 08:38 PM
Targus
30
Jul 2, 2008 07:12 PM
rmalottwtes30
15
May 6, 2008 05:40 AM
fellro86
Sep 20, 2006 07:29 PM
f2fiddy
27
May 2, 2004 09:14 AM
