Insulated Concrete Forms
Old Jan 1, 2007 | 10:56 PM
1975Ford's Avatar
1975Ford
Happy New Year .
What tubing is long lasting for the Hydronic Radiant Heat Sytems ?
I have seen different brands.
Which is a good brand of boiler?
I thought of going with forced air for the heating / air conditioning, and was a bit on the pricey side.
Old Jan 2, 2007 | 02:35 PM
mblayton's Avatar
mblayton
Originally Posted by 1975Ford
Happy New Year .
The tubing used in my addition was PEX and it was red in color, but have seen it in different colors, boiler not to sure yet still looking into it, my current system runs off my hot water tank 60 gal but then I only have two zones. The new house I am building this year will probably require 8-10 zones
Old Jan 2, 2007 | 03:03 PM
seventyseven250's Avatar
seventyseven250
with the PEX, you can do Red for hot water and blue for cold, that way whenever you run across a pipe in the wall during construction or renovation, you'll always know what's in it. They also have a white / neural color if you want to do everything the same.
Old Jan 2, 2007 | 05:20 PM
1975Ford's Avatar
1975Ford
It seems there are different model of PEX tubing.
The different color tubing make sense as mentioned.
When laying down ICF's, the footing (Footers) cannot be off 1/4" of each other.
I decided to go with the 6" internal width ICF's.
Old Jan 2, 2007 | 11:45 PM
chrono4's Avatar
chrono4
We make the polysteel forms at work, and yes they are more expensive initially. The money you save on heating and cooling should easily make up for the higher cost. The're also very sturdy stuctures, as contractors are using alot of them for houses in hurricane areas. We dont make it here, but there is a product I beleive is called waffle grid that is meant for floors, and can be used with radiant heat floors.
Old Jan 3, 2007 | 12:14 AM
Torque1st's Avatar
Torque1st
Posting Legend
Old Jan 3, 2007 | 09:53 AM
1975Ford's Avatar
1975Ford
chrono4 & mblayton, you mention cost savings with ICF's, would you know how long the cost savings would be to recoup the added cost of ICF construction.
Torque1st, thanks for the links, found this in one of the links and list other ICF companies http://www.pbf.org/archive/ICF%20comp%20chart.pdf
Two Questions.
I am planning on using ICF's on the exterior portion of the house only.
Just wondering if anyone knows what the cost ratio difference, stick (lumber, insulation, electrical, etc...) vs Insulated Concrete Forms (ICF's, Bracing, concrete, electrical, etc...) would be for a 202' perimeter rectangular shaped house with 8 foot walls?
Approxiamately how much rebar would be needed for this 202' perimeter rectangular shaped house with 8 foot walls?
PS: The interior portion is going stick built.
Old Jan 3, 2007 | 12:34 PM
mblayton's Avatar
mblayton
Two Questions.
I have not built yet but have been told that the cost difference is recouped in as little as 5 years in your heating/cooling costs. I have also been told that the cost of ICF's is as little as 1% to 7% more than stick framing, not a huge difference considering the time savings you would have doing it this way, once you do your pour all you would need is electrical then drywall no fussing with insulation, stapleing vapor barrier then drywall, same goes on the outside you are ready for finish siding or stucco right away.
Old Jan 3, 2007 | 01:09 PM
1975Ford's Avatar
1975Ford
Here is a handy material estimator http://www.a-1form.com/html/estimator.html, I'm running my own numbers to verify if the estimator is accurate.
Old Jan 5, 2007 | 01:04 AM
1975Ford's Avatar
1975Ford
Where can I find a good rebar bender and rebar cutter? Or should I rent one?
How do I hold up the rebar up during the stem wall pour?
mblayton, are you planning on doing the ICF setup yourself?
It does seem like lots of rebar and (door and window) bucks?
It did mention that the outside perimeter will need stucco mesh and larger head screws.
Old Jan 5, 2007 | 02:10 AM
DOHCmarauder's Avatar
DOHCmarauder
My neighbor behind me just started construction using this system.
Kind of freaking me out........I'm digging the R value (even though at R23 in my 6" stick walls I've only used my furnace 4 or 5 times in 2 years....A/C is a different story)but don't you have to do an inner stick frame for romex/receptacles, central vac etc..?
The other thing is the one coat of stucco over the foam.........I used a 3 coat (last coat synthetic) over lathe with foam trim, the trim/foam is so fragile!!!
I'll be watching this project and learning as it goes.
Old Jan 5, 2007 | 02:18 AM
chrono4's Avatar
chrono4
for outlets they just cut out the foam behind it and fasten the boxes to the cement/drywall
Old Jan 5, 2007 | 11:34 AM
  #28
mblayton's Avatar
mblayton
Yes I plan on doing the whole setup myself, I do renovation work outside of my job at Ford. I am going today to get the info and inside scoop on this whole system
Old Jan 5, 2007 | 02:19 PM
  #29
1975Ford's Avatar
1975Ford
We will be waiting to hear the scoop on this whole system.
Toyman, pm is in. Can't wait to see the pictures.
I doing some research too, I have e-mails to an abbundant ICF headquarters, branches, and local distributors. The e-mails and Phone calls are flying back and forth, I will need to sort thru all the mails, notes, and brochures and website. I also got an appointment to visit on-site Amvic ICF construction.
There is some other good brands of ICF's.
It seems everyone joining in the ICF boom construction. Found a website where they were trying to sell the patent to their ICF design and construction.
Does anyone have any answers to the previous questions?
I greatly appreciate all the information.
Old Jan 5, 2007 | 02:44 PM
  #30
Toyman's Avatar
Toyman
I just sent you 15 pictures of the basement. Let me know if you can't open them, or they don't come through.
Toyman
