1978 - 1996 Big Bronco
Tach Stopped
Old Dec 28, 2006 | 11:26 AM
SCOOBYMEISTER's Avatar
SCOOBYMEISTER
Tach Stopped
85 Bronco 351 W H.o. Auto Dual Exhaust (true Duals) Long Tube Headers With Two Cats And Two In Two Out Magnaflow Muffler. In The Process Of Installing My Dual Exhaust, Which Btw Was A Total Pain In The ****, My Tachometer Stopped Working, There Are Two Wires Leading To The Coil And Both Are Tight, Any Hints On Where To Start Looking For The Cause? Yes, It May Just Be That The Tach Is Dead, But I Figured It Does Not Hurt To Ask, Thanks
Old Dec 29, 2006 | 08:38 PM
plowhand's Avatar
plowhand
Playing in the Dirt
First, I woudl check all of your fuses. Then (I know you don't want to hear this) start tracing wires to see if anything got cut, burned or pulled loose.
Old Dec 30, 2006 | 01:05 PM
81-F-150-Explorer's Avatar
81-F-150-Explorer
Follow the tach test wire off the coil.
There should be a couple of more connectors on the left fender panel where the tach wire "Y's" off. One goes to the ignition module, or computer, etc... the other goes to the tach in the dash etc..
Should be a green/yellow stripe color wire you are looking for.
Rusty_S
Sep 8, 2015 01:08 PM
bcamill
May 31, 2015 07:59 PM
rchad23
Computer Chips & Tuners
Jun 22, 2006 11:16 AM
tonga3
Exhaust Systems
Jun 9, 2003 02:50 PM
ariel
Apr 27, 2001 11:54 PM
