Starting Problem
Old Dec 27, 2006 | 07:53 PM
ou814us2's Avatar
ou814us2
Starting Problem
I have an 88 f350 with a 7.3l and after it sits overnight it seams like the fuel is leaking back into the tank cause it take alot of cranking to get it started. does this even when block heater is plugged in. any suggestions?
Old Dec 27, 2006 | 09:09 PM
KJLYPW's Avatar
KJLYPW
Well known problem! Grey hoses on return line system? Original hoses leaking air, also o-rings on injector return caps get hard and leak air. Replace all injector orings and return line hoses. Kits available with cap, hose, clamps on line. "Injector return line kit" search should give you secveral options on e-bay.
Old Dec 27, 2006 | 09:50 PM
Dave Sponaugle's Avatar
Dave Sponaugle
ou814us2,
Welcome to FTE and the IDI forum.
As KJLYPW said it is probably the return lines and O rings on the injectors, common problem.
B1GKAHUNA
Jun 15, 2014 02:05 PM
equine_21
Jan 15, 2003 04:14 PM
Redneckerson
Mar 15, 2002 07:49 PM
mrshorty
Feb 28, 2002 04:18 PM
Pastmaster
Dec 4, 2001 04:36 PM
