96 f150 Ignition switch help
Old Dec 27, 2006 | 05:38 PM
pegg1's Avatar
pegg1
Truck will not turn off.It will start but when you turn it back to off position it move freely does not click like its suppose to.So I replaced the lock and key cylinder and it still does the same thing.So some type of linkage must have broke.I think it might be behind the lock and key switch but it does not look accessable.My haynes manual does not really break it down very good.Any help please.why wont it turn off.
Old Dec 27, 2006 | 06:17 PM
quicklook2's Avatar
quicklook2
search actuator switch.
that or the rod to it is broken.
Old Dec 27, 2006 | 09:33 PM
pegg1's Avatar
pegg1
where is the acuator switch
Old Dec 28, 2006 | 03:21 PM
pegg1's Avatar
pegg1
Okay I figured it out.The pin that connects the cam rod to the actuator rod is gone both plastic rods are okay the pin that connects them is the only problem.So went to Ford bought a new cam and pin had to buy the whole cam to get pin.Anyways the new pin is pressed into the cam.So I want to replace whole part but cannot not figure out how to get the cam rod out and cannot figure out how to get the actuator rod out either. Can someone tell me how to get these to Rods out so I can fix it.
Old Dec 28, 2006 | 08:54 PM
pegg1's Avatar
pegg1
anybody give a little help
RBerry9511
Feb 7, 2020 04:31 PM
dh_meyer
2009 - 2014 F150
Apr 11, 2015 11:57 PM
Frozen_Joker
Sep 25, 2010 09:23 PM
campbells111
New Member Introductions
Feb 6, 2009 09:29 AM
5fingerblu
Aug 6, 2008 09:12 PM
