Changing fluid in 9" rear
Old Dec 26, 2006 | 05:34 PM
strokerfe's Avatar
strokerfe
I have a '76 f150 9" rear with 3.89 gears and was wanting to service the fluids in it.
I have never jacked with a rear diff. before and was wondering what the easiest way would be to drain the fluid.
(Since there is no drain plug)
Do I actually have to pull the third member to drain the fluids.
Thanks, Al
Old Dec 26, 2006 | 05:58 PM
ncl's Avatar
ncl
According to my manual and past experiences it is suck the old fluid out through fill hole with a manual suction pump device or pulling axles out part way then removing the whole third member.
Old Dec 26, 2006 | 06:31 PM
WarWagon's Avatar
WarWagon
If you are going to suck it out, make sure you do it hot or you will be under there until next Christmas.
Old Dec 26, 2006 | 06:59 PM
oldfordtrucksrule's Avatar
oldfordtrucksrule
i use my mityvac vaccuum pump to suck out the gear oil on mine. the fill plug hole lets u get in the housing with a small hose and remove the oil. parts stores sell em.they work good for empting brake master cylinders and ps pumps too. the ring gear is in the way if u try to stick anything in the 3rd member, but just jab the hose around till it goes down to the bottom of the housing. i thought about installing a drain plug on mine, but im too lazy anymore,lol.
Old Dec 26, 2006 | 09:20 PM
strokerfe's Avatar
strokerfe
Thanks for the input; I was considering the pump idea and thought it would be alot easier
than pulling the third member, but someone had told that a hose would get caught and that I would not be able to get it out if I tried.
This sounded kind of strange to me so I thought I would just ask and confirm.
Thanks for the reasurance; Al
earthworms
44
Jul 10, 2022 03:54 PM
78 & 87 Super Cab
Sep 5, 2016 05:55 PM
Avbird
Nov 9, 2009 09:57 AM
mfp4073
1983 - 2012 Ranger & B-Series
23
Jun 15, 2009 08:59 AM
MJEmerson
Jan 28, 2004 11:29 AM
