Limited slip differential fluid question
Old Sep 5, 2016 | 07:56 AM
78 & 87 Super Cab's Avatar
78 & 87 Super Cab
Question Limited slip differential fluid question
When "topping off" a limited slip axle (like adding less than 12 ounces or so of fluid) would I have to add the friction modifier additive as well? I can see having to do it, like when doing a drain and refill.
The axle code in My 1994 F150 according to the door sticker is H9. Looking at the rear cover, i see no tag saying use limited slip additive, the tag on it says the following:
S847F
3L55 88 3K25
Old Sep 5, 2016 | 11:24 AM
Lead Head's Avatar
Lead Head
Add it in proportion to the amount of regular oil you added.
To be fair, it's pretty likely your limited slip is worn out anyways, so it wouldn't matter.
Old Sep 5, 2016 | 05:29 PM
east302's Avatar
east302
The 3L55 means it is a limited slip 3.55. They only take 4 ounces of the friction modifier during refill, so it's not a lot. I'd just top it off with a gear oil for limited slips or even the regular stuff, it probably doesn't matter.
If you're having to add fluid, check for leaks.
Old Sep 5, 2016 | 05:55 PM
78 & 87 Super Cab
Thanks for the info, Mine is not leaking and level is full.Will use this for future reference
NinthGenF-SeriesOBS
Apr 20, 2016 05:50 PM
Camper Special Gene
Apr 16, 2014 05:05 PM
gmetime24
May 21, 2011 04:22 PM
KoolAidMan888
Nov 21, 2010 02:20 PM
fordyduty
Mar 1, 2010 02:49 AM
