45-47 Cab
Old Dec 24, 2006 | 04:05 PM
maddog200485's Avatar
maddog200485
45-47 Cab
I was wondering if the 45-47 truck cab is the same as the 40 ford truck cab
Old Dec 24, 2006 | 05:25 PM
3Mike6's Avatar
3Mike6
I've been told that from 40-47, only difference were the gas tank filler hole.
But I also wonder about the dash gauge assembly? and if it's correct to span the years?
Old Dec 24, 2006 | 05:26 PM
3Mike6's Avatar
3Mike6
BTW...welcome Aboard to FTE!
Old Dec 24, 2006 | 05:34 PM
NumberDummy's Avatar
NumberDummy
Ford Parts Specialist
O1C to 21C
Gas neck location changed in 1942, as was the dash gauge cluster. New frame, bed and front sheet metal in 1942.
My ref makes no mention if 1940/41 cab is different than 1942/47.
Old Dec 24, 2006 | 11:22 PM
45ford's Avatar
45ford
The front fender mount bracket is also different. I think that the '40/41 is repopped by someone for facilitate using the later cabs as a '40.
And...the 42-47 has an in-cab, under-the-seat gastank while the '40/41 is frame-mounted behind the rearend, so the floor under the seat is different (or missing! )
Mike
Old Dec 24, 2006 | 11:39 PM
46fordtruck's Avatar
46fordtruck
maddog200485, welcome to FTE, hopefully this thread will answer any questions you may have.
Simply put, as a whole, you can use the '40-'41 cabs on a '42-47 frame, and vice versa. There are some small detail stuff, but they interchange.
Melansk
Jun 15, 2017 06:50 PM
ladelld33
28
Oct 20, 2016 02:10 PM
ek510
Jun 1, 2015 02:12 AM
mjpaldino
Modular V8 (4.6L, 5.4L)
Apr 20, 2012 06:04 PM
jimbo81587
Apr 23, 2004 10:28 PM
