How to replace welded body nuts?
Old Dec 23, 2006 | 11:04 PM
NormH's Avatar
NormH
My '56 has three nuts that were factory welded to the body broken loose. One holds the left gas tank bracket to the cab rear. Another holds the tailgate hinge to the bed. The third holds the left hinge top to the hood and concerns me the most. Any advice on how and what to replace these nuts with? Where do you get replacement nuts?
Old Dec 24, 2006 | 04:08 AM
Randy Jack's Avatar
Randy Jack
I replace the broken factory weld nuts with flange nuts. I bolt it up to hold it in place, then tack weld the flange to the sheet metal. I used them for the front fender and inner fender factory nuts.
If you have finished paint that you dont want to damage from welding, you probably should just use a regular nut in place of the weld nut, provided you can get a wrench on it.
Old Dec 24, 2006 | 09:25 AM
AXracer's Avatar
AXracer
If welding is an option drill a 3/16" hole right next to the nut. OK if you nick the nut, but you need to get the hole so it touches the side of the nut, hole doesn't need to be perfectly round, so just worry it over until you are against it if you missed a little. Now just plug weld fill the hole.
Old Dec 25, 2006 | 12:43 PM
fking1's Avatar
fking1
Mid Fifty sells a hood nut repair kit for the weld nuts that come off. I used it for one of my hood hinge bolts and it works.
Fred
Old Dec 25, 2006 | 04:31 PM
jniolon's Avatar
jniolon
old and in the way
another option if you have a fraction of an inch around the hole is a rivet nut sometimes called nutserts. I wouldn't put a life supporting load on them... but for the tailgate hinge or gas tank bracket they will work fine... the hood hinge too probably since there are more than one bolts holding this part... you might try a google search on rivet nuts to find a local distributor... come in all sizes from 8-20 up thru 5/16 or so
here's one source... more on google
rivet nuts
and another
they take a special tool to insert them...sorta like a pop rivet tool on steroids...but they aren't terribly expensive and can be used for lots of projects... car makers use them for mirrors, luggage racks, etc
later
John
Old Dec 26, 2006 | 11:17 PM
CIAF's Avatar
CIAF
Or a bent ( as a handle ) allthread with two nuts and an oiled or greased washer between the two nuts..... Use 2 wrenches to spread the rivnut. This will allow for using all sizes and buy no tools. However, the 40.00 tool is like the best tool ever and works like magic.
Old Dec 27, 2006 | 04:51 AM
4tl8ford's Avatar
4tl8ford
There are also "Caged" nuts that are held in place by small rivets or Tac welds.
The Rivenuts and the Caged nuts have been around for along time in the Aircraft and Auto Industry.
Old Dec 27, 2006 | 04:05 PM
fking1's Avatar
fking1
Fred
Buy the kit and you have a sure fire repair. No need to mess around.
Fred
df85732
Nov 4, 2015 06:45 PM
danielcoyle
23
Nov 7, 2014 09:06 PM
hhight
Jul 29, 2014 06:08 PM
alchemist1
May 6, 2014 02:30 PM
Dannyb123
Nov 18, 2013 03:49 PM
