BW1356 with speedometer adapter
Old Dec 22, 2006 | 10:55 PM
Little Foot's Avatar
Little Foot
Question BW1356 with speedometer adapter
looking for a new tail shaft for a BW 1356 transfer. one with the adapter for the speedometer. I recently destroyed my 8.8 and replaced it with a 9 inch, so now I have no speedometer. Any help would be greatly appriciated.
Old Jan 11, 2007 | 06:48 PM
amish77's Avatar
amish77
so you can't get the speed from the tranny?
Old Jan 11, 2007 | 07:07 PM
javi2001's Avatar
javi2001
If that truck is 1992 or over, the speed sensor at 1356 output shaft is not going to work UNLESS you use some sort of electronic adapter to get the proper pulse per mile signal.
More over you need also change the T-case output shaft and obtain the pinion ring and metalic sphere wich is used on T-case 1991 and older.
Old Jan 11, 2007 | 07:43 PM
fatboyf150's Avatar
fatboyf150
there is a special retro fit kit made for this problem. it has a replacement yoke for the 9 inch and a mount kit for the sensor. i just cant remember what magazine i was it in. i only have about 600 4wd mags. as soo as i find it, ill im you.
Old Jan 12, 2007 | 05:56 AM
Little Foot
thanks a ton
Old Jan 12, 2007 | 06:02 AM
Little Foot
I will be chaning out the entire gauge cluster. I am pulling all of the wiring harness to get rid of the computer. I will be using a universal wiring harness from painless to wire the truck.
Old Jan 12, 2007 | 09:38 AM
95Ford4x4's Avatar
95Ford4x4
another 8.8 axle would be cheaper and simpler to do. if your truck is new than 92 that sensor in the axle is going to control your abs, speedo, and cruise control. which is a lot of work to rewire.
Old Jan 12, 2007 | 09:47 AM
95Ford4x4's Avatar
95Ford4x4
on the other hand. i had put a painless wiring kit in my 78 f150 4x4 and it was by far the best investment i put into that truck. only problem i had was the ignition cause ford changed colors so often it took a couple of tries to match everything up with the kit. if you can get everything wired up it will be good, but that's going to be a lot of work.
Old Jan 12, 2007 | 04:31 PM
Little Foot
8.8 will not hold up to the hp and torque of a blower motor. I am not real sure that the 9inch will. But we shall see. As far the harness goes, it will be cheaper and easier in the long run.
Old Jan 16, 2007 | 06:56 AM
95Ford4x4's Avatar
95Ford4x4
9inchers are run by dragsters, they will hold up to the power, but depending how much power you are going to run you may need to step up to 35 spline shafts.
Old Jan 16, 2007 | 11:55 AM
Little Foot
The only problem with going up to 35 spline axles is that I would have to change housing to accomidate the larger bore bearings. At least as far as all of the research I have done so far. That is why I am staying with the 31 splines that are in the housing. If or more likely when they break I will up grade.
Old Jan 28, 2007 | 08:00 PM
amish77's Avatar
amish77
might be 31 spline Chrome Molys out there. If there are they'd be worth the time. Less work at modification and higher strength.
hjartland
Feb 7, 2017 12:30 PM
abosely
Dec 10, 2015 01:26 PM
abosely
Nov 23, 2015 06:06 AM
irhunter
Jun 16, 2015 04:52 PM
FordPerf300
15
Jun 8, 2003 11:08 PM
