96 down pipe
Old Dec 22, 2006 | 06:33 PM
79fordranger's Avatar
79fordranger
96 down pipe
i am new to the sight. i have a 96 7.3 f350. i would like to put a 3in down pipe on it after the turbo. can this be done ,and if so how?
Old Dec 22, 2006 | 06:43 PM
plowhand's Avatar
plowhand
Playing in the Dirt
Yes, it is highly recommended, also you might want to consider deleting the CAT while your at it. Buy a down pipe, unbolt the cat from the bottom of the down pipe (I would also remove the cat to give yourself more room), unbolt the top of the down pipe, push the down pipe up as far as you can, use a sawzall to cut off the cobra head, push the pipe down and cut it again and then work it out.
Then use a porta-power (the easiest) or wood block, pry bar and hammer and flatten the firewall seam. Then install the new down pipe and/or cat delete pipe.
Check the vendors on this site for a down pipe and cat delete pipe.
Old Dec 25, 2006 | 02:16 PM
79fordranger
thank you for the info. i boutht the down pipe a couple of months ago. some people i talked to told me this could not be done. i did not think they would sell a product that could not be used. thet told me the only way to do it was to give the truck a 3in lift and loosen the motor mounts and slide it forward. once connected slide it back. have you done this before? how much of a difference did it mack? P.S. i already have a straight pip on it.
Old Dec 26, 2006 | 09:13 AM
F350_Hauler's Avatar
F350_Hauler
No need to loosen the motor mounts. Cutting the old one apart to get it out of there is necessary. A 2" body lift actually makes for enough room to put the new one in without bending the firewall seam lip. 3" would make it even easier. A 2" lift can be installed without any major modifications to linkage and shifting levers. With a 3" lift you will probably have to substantially alter your shifting and 4X4 levers to get them to come up far enough to get through the floor and then be the right shape to still fit the layout of the floor shape. I highly recommend the 2 inch lift kit!
Old Dec 26, 2006 | 05:23 PM
plowhand's Avatar
plowhand
Playing in the Dirt
As stated above, you can install the down pipe on a stock truck by flattening the firewall seam. Just make sure you do a test fit to make sure it is not touching the firewall or it will sound like your trucks coming apart when you run it.
Old Dec 26, 2006 | 07:21 PM
tjbeggs's Avatar
tjbeggs
to clarify for you, you don't need a lift to fit the pipe. It does require cutting the large pinch weld in two spots and bending it flat against the firewall. cutting the old pipe out is needed. get a good sawzall or torch or plasma cutter and cut as far down from the top in the engine compartment as you can the pull the top piece out the top and the bottom piece out the bottom.
Old Dec 26, 2006 | 08:21 PM
ltfox's Avatar
ltfox
Here is some good instructions on the install w/pics
Good luck
http://www.drivetrain.com/downpipeinstinstr.html
The only thing I would'nt recommend is the heat wrap. Traps moisture agaist the pipe and can cause corrosion.
Old Dec 28, 2006 | 06:06 PM
79fordranger
thanks yall you have saved me a lot of heart acat
Shawn MacAnanny
Dec 15, 2016 09:53 PM
Dutter 2
30
Aug 19, 2016 11:25 PM
jimbo beam
May 21, 2016 08:51 AM
razors_edge09
May 2, 2015 05:13 PM
disfunctionals
Exhaust Systems
Oct 31, 2006 12:45 PM
