paint sprayer type?
Old Dec 21, 2006 | 05:37 AM
Oregon Bob's Avatar
Oregon Bob
paint sprayer type?
Hi! I am thinking of spraying my 53 f100 myself, I have done a 51 8n tractor and it turned out pretty good. overspray was no problem at the time, but I am in a different location now. I knew a guy that used to take his projects apart and
spray them a piece at a time in his driveway. He never had a complaint from close by neighbors and never had a overspray on his concrete. Quality was OK for a driver and I would be satisfied with it on mine. Any ideas what he used?
All he ever said to me was he used a real small gun and sprayed a type of enamel.
Thanks , Oregon Bob
Old Dec 21, 2006 | 09:00 AM
49willard's Avatar
49willard
If you are considering spraying your own truck outdoors in pieces, I would make sure that I had one of the HVLP (high volume low pressure)guns (less overspray than the old guns). You need good repiratory protection-particularly with the newer paints. Get a tarp on the driveway to protect from overspray (there will be some). Wet the tarp and surrounding area to minimize dust from your movements and dragging a hose around and spray on a calm day when you will not have a flying insect problem in the paint. If you do everything right you will not duplicate the result that can come from a good downdraft paint booth. If you are really considering going this route, I would really consider having at least the exterior surfaces (final color) shot in a good both. Greater than 95% of the effort in the paintwork will be the prep. All of that prep work of metal repairs, priming, blocking, pit filling, etc,etc., etc., can be readily accomplished at a home shop or if necessary on a driveway without suffering the end quality of the paint.
Note that I have restored a number of my cars in the past doing all of my own body and paintwork. This time I will get the final primed and blocked sheetmetal into a booth. I may or may not actually hold the spray gun.
Old Dec 21, 2006 | 09:27 AM
Huntsman's Avatar
Huntsman
One other thing to consider is the paint type. My experience with enamels is they are slow to cure, taking hours instead of minutes. A good urethane single stage will give a similar look but will dry in a very short period of time, 15-20 min depending on the paint and additives used.
As 49willard has mentioned everything up until the final paint can easily be done without affecting quality of the final paint. Renting a paint booth from a local body shop and using his 'high volume dry' air can make a world of difference in the final results.
Old Dec 21, 2006 | 09:48 AM
WALFORD'S 56's Avatar
WALFORD'S 56
Oregon Bob--I have done what you suggest many times.I have 30 years of painting experience,and have made alot of mistakes,but when it comes to painting your own truck,etc--1 rule applies!!TAKE YOUR TIME!!I lay down cardboard,from a big appliance and do it piece by piece.You don't get overwhelmed when you contemplate every move.You said you do not care if it a perfect job!That is a good attitude--but don't forget others will compare your quality of bodywork/paint with professional jobs that cost them thousands of dollars!I think you go at it and use a hvlp and use base coat--it dries faster and then resand where the bugs,dirt get in it.I ALWAYS TOLD MY EMPLOYEES--1 thing about painting-you can always sand it and do it again!!Not true in machining an engine,etc.Once it is scrapped it may not be fixed.Paint on a nice day,and go at it slow and learn from your mistakes.GOOD LUCK
LabCab
6.7L Power Stroke Diesel
35
Oct 1, 2019 02:05 PM
Robert6401
Paint & Bodywork
Jun 15, 2009 11:55 PM
Robert6401
Jun 4, 2009 11:23 AM
CptSD
Paint & Bodywork
19
Jul 22, 2007 09:40 AM
berkad
Appearance & Dress-Up
15
Jun 13, 2006 10:14 PM
