Easiest/cheapest way to paint inside of bed?
Ok, so I have a black 2003 F250. I bought it used back in 2004. It had a drop-in bed liner since I bought it. I recently bought a 5th wheel, and when the dealer installed my hitch they removed the drop-in liner because it would interefre with the hitch. No problem, except that the bed underneath the liner is WHITE! I guess this was a replacement bed at some point, you can see the overspray where they obviously just painted the areas outside of the bedliner black. Anyways, there are a couple of small rust spots that will need to be tended to, but mainly I just want to cover up the white bed on my black truck. Now, my truck is a good looking truck, but it is a truck and I treat it as such. It has a few scratches here and there, and I'm not overly concerned with the bed looking pretty. I don't want it to look totally sloppy, but I dont want to spend $400 or more for a spray in liner, either. I have never painted anything to speak of, so I am looking for an easy, effective way, to paint the bed black without a lot of fuss. Honestly, if I can paint it somehow now and it last a couple years until I am more inclined to put in a spray in liner, that would be fine. Can you guys point me in the right direction? Thanks for any advice.
Bob
Bob
As an option....scotchbrite the area and stop by Mayco, 1day paint & body, etc and see how much they want to just spray the bed.....chat with th manager to see if they have another black Ford coming in for a paint job (or any black vehicle) and explain you're not that interested in a perect match, just as long as it's shiney 7 black- they may very well cut you a good deal!
Macco = badd news....I dont care how cheap they are....you get what you pay for.
I would do the Herculiner as stated above. Just make sure you prep the bed as per the instructions. I want to do this to my bed sometime down the road, I really am starting to hate my plastic liner.
You could also sand it down, get a good enamel paint and brush or roll it on as well.
If you can sand something, i would sand it and have macco spray it, after all, it is the inside of a pickup bed
Because of the volume, most of the painters at these 1-day paint places are really good painters. the paint that they use is name brand as well (such as GE, Sherwin Williams Automotive, etc.) and specifically designed for "fast dry" applications. They all use a hardener and typically have excellent durability- where the crutch is- is the prep. Soem just acid wash the vehicle and looking like an army of ants...allow 3 minutes for surface sanding. while others actually sand the paint and apply a sealer.
Maaco & 1-day are probably the better of the group but Earl Schieb has some nice finishes too (if you do the prep work yourself)
Just finished Herculining my second early Bronco. The first one was done a year ago and is holding up fine. The stuff is pretty good for the price. Just be aware that it will fade in an uncovered truck bed. They say there is a spray UV inhibitor to cover it, but I have no experience with it. If you got an 8 ft. bed, get the kit plus an extra quart. Plan for a full day to do it, takes awhile for the first coat to dry.
I beg to differ. I had Macco do a full paint job on a mason dump about 5 years ago. I did ALL the prep work. From dent repair , priming, removing trim,glass, grill and wetsanding. All they had to do was tape of the window openings and wipe it down. The total cost to paint the entire truck(cab and dumpbody+ extra quart of paint) was $440. That was in red, non clearcoat(as was the factory paint.) at the time for me to buy the red , non clear coat paint, it was over $800. So being i had nowhere to spray the truck,i let macco do their thing. NOW 5 years later, the truck looks almost as it left Macco, Perfect!!! Prep is everything.
I have repainted stuff that Macco has painted before. The guy I used to do body work with would always ask new customers if the vehicle was ever painted by Macco. If so, we would go down to either factory primer or bare metal.
TrailKroozr
Bed Covers, Tonneau covers, Toppers/Canopies & Bed liners
03-03-2017 10:35 AM
BarryH
2015 - 2020 F150
06-30-2016 09:35 AM
