help! high idle!
Old Dec 20, 2006 | 10:32 PM
84f250460's Avatar
84f250460
help! high idle!
i need some help again.... my 84 300 I6 is idling around 1500 RPM. i havent ever really messed around w/ a 1Bbl so waht exactly has to b adjusted?
Old Dec 20, 2006 | 11:00 PM
Mo52Merc's Avatar
Mo52Merc
On my 77, there is a screw in the throttle linkage on the back side of the carb and lies parallel to it (NOT INTO the carb) If it is set too high, you may be able to unscrew it some to adjust the idle speed. That's all I've had to do on mine to adjust the idle, but yours may be different. Good luck.
Old Dec 21, 2006 | 10:48 PM
84f250460's Avatar
84f250460
how far do u think i will have to unscrew it roughly?
Old Dec 23, 2006 | 01:46 PM
Harte3's Avatar
Harte3
High idle condition in my '83 was not the carb...the EGR valve was shot.
Old Dec 26, 2006 | 07:59 PM
javi2001's Avatar
javi2001
It sounds like Climatic Control got stuck, beffore touch anything else, check the climatic control spring & valve for proper operation.
nerdpcr
Sep 13, 2014 12:01 PM
dburch84f350
Jul 9, 2011 08:26 PM
1949f1
1983 - 2012 Ranger & B-Series
Jan 4, 2009 05:50 AM
WrenchHead84
Oct 15, 2002 09:16 PM
